Appearance ?
Old Oct 2, 2023 | 10:14 AM
OldBlue61's Avatar
OldBlue61
Looking really good. I went through a similar spark issue recently. Turns out it was probably just a fault in the signal wire to the coil, but I put a new distributor in it anyway. Runs better than ever. Driving it daily again now that it’s cooling down.
Old Oct 2, 2023 | 11:31 AM
User 71024's Avatar
User 71024
Are you having overheating issues when it's hot out?
Old Oct 4, 2023 | 11:22 AM
OldBlue61's Avatar
OldBlue61
Since I added a belly pan I have no overheating issues whatsoever. I have a manual switch activated electric fan only, and it never turn it on unless stopped in traffic. I live in Florida, but don’t drive it much in the summer.
I have the same gas fill problem you have also. I dropped the tank once and looking at the design I think it’s just the nature of the beast. With no nozzle hole and splash preventer in the fill neck like modern cars, I don’t think there is an easy cure.
Old Oct 5, 2023 | 04:02 PM
User 71024's Avatar
User 71024
I'm not using the stock tank, I installed a 19 gallon behind the right rocker panel and put a fill and vent up high on the bed side panel. So I created the issue I'm having, just have top redesign my filler.
jimmy_stikx
Electrical Systems/Wiring
Aug 14, 2014 07:30 AM
Talyn
Oct 18, 2009 10:45 PM
TN_Explorer
Feb 1, 2005 09:14 PM
Lane Dexter
29
Nov 10, 2004 04:04 PM
Racerdave
Dec 14, 2002 05:06 PM
