87 F250 gear ratio
Old Mar 8, 2000 | 07:36 AM
truckinaround25's Avatar
truckinaround25
87 F250 gear ratio
Can anyone help me out in finding out what the gear ratio is on my F250 2wd auto w/300I-6. The tranny code on the door jam is "K" and the axle code is "29". I would like to either replace the gears or rear end in order to up my mileage a little, I use the truck mainly to commute to work, 35 miles one way. I am getting 13mpg and that's not quite cutting it. I was told there is a 3 speed tranny in it. Please help!!!
Old Mar 8, 2000 | 12:42 PM
kylec27's Avatar
kylec27
87 F250 gear ratio
code 29 is a 3.55 gears
Old Mar 8, 2000 | 03:33 PM
slikness's Avatar
slikness
87 F250 gear ratio
I'd consider swapping you my 2.73 rear gears out of my '82 F150.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Mar 8, 2000 | 04:17 PM
stevieboy's Avatar
stevieboy
87 F250 gear ratio
The K code if it is the same as 82 is the c6 tranny.
Steve
Old Mar 8, 2000 | 05:20 PM
truckinaround25
87 F250 gear ratio
Thanks for all the help guys.
Slik, Where do you live and how hard would it be to pull the gears myself with a standard set of tools?
Old Mar 8, 2000 | 06:22 PM
slik's Avatar
slik
87 F250 gear ratio
I live in Durham, NC; it would probably be easier to swap the entire rear end drum to drum. From what I hear, it's a pain to swap the gears and get them setup. How about it folks, maybe some comments from those that really know?? I know I can pull my rear hub to hub with common tools, but I don't know about the gears, etc. Oh, I assume you have the 9" rear?
Slik
Old Mar 12, 2000 | 10:28 AM
truckinaround25
87 F250 gear ratio
I couldn't tell you if I have a 9" rear end or not, still a little green to working on Fords and trucks for that matter. Been a parts replacer for a long time.
Old Mar 12, 2000 | 06:39 PM
PBOCfish's Avatar
PBOCfish
87 F250 gear ratio
If it's an F250, it's not a 9".
Old Mar 13, 2000 | 11:31 PM
deleontow's Avatar
deleontow
87 F250 gear ratio
SoloAK
33
Aug 9, 2016 02:00 PM
darren_palms
Dec 16, 2013 01:19 PM
Swany89b
Dec 4, 2013 09:17 PM
okiebug71
Apr 29, 2010 02:05 PM
7FORD2
Dec 30, 2005 06:44 PM
