ABS Wiring
Old Mar 9, 2022 | 12:04 PM
Ronnie Shierling's Avatar
Ronnie Shierling
ABS Wiring
I had a blowout on the interstate on the driverside front. The brake line was busted as was the ABS wire. I have the wire to replace it but not sure how to run it, as well as where it connects to other than the wheel speed sensor. I have googled it, youtubed it with no luck. Any and all help is very much appreciated. Thanks in advance
Old Mar 9, 2022 | 12:09 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
It connects to the pig tail from the main harness right behind the wheel well by the front edge of the running board. It has a plastic fastener that hold the plugged connection to the wheel well liner.
Old Mar 9, 2022 | 12:10 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Check your psgr side for correct routing of the wire.
Swisspsd
Jul 20, 2018 04:18 PM
ptrnfan
1997 - 2003 F150
Sep 5, 2007 03:05 PM
IronMiner
1997 - 2003 F150
Apr 21, 2006 11:36 AM
AllFords1022
Jan 8, 2004 01:50 PM
