400 HP Engine Build - Input Needed
#136
The following users liked this post:
#137
#138
Reading over the International manual, it looks like they specify 95ft-lb for the bearing cap bolts (oil coated if re-using). Thing is a class 10.9 fastener for that size is notated in the manual as 79ft-lb (+/- 10%). Has me wondering if the bearing cap bolts and connecting rod bolts are reusable? If they are tightened that much have they permanently stretched?
#139
#140
#141
The following 3 users liked this post by KubotaOrange76:
#142
#143
The following 2 users liked this post by Bitterroot Diesel:
#145
#146
#147
#148
#149
#150
Rod bolt kit is on indefinite backorder, and the stock bolts are discontinued so I might have to re-use the rod bolts. @Bitterroot Diesel Don't suppose you have any floating around your shop?
