Seat Spring
Old Mar 6, 2022 | 06:08 AM
turnrjr's Avatar
turnrjr
Seat Spring
I've been preparing and repairing my 54 seat frame and springs for a new seat cover. These two springs were positioned under the driver position. The coil spring is broken on both. Has anyone found replacement springs for these?
Old Mar 6, 2022 | 07:04 AM
abe's Avatar
abe
Those are called seat snubbers, designed to take the bounce out of the seat when you hit a bump. They don't look broken to me. I've never seen reproductions made, either for the spring or the whole snubber. You don't really need them.
Old Mar 6, 2022 | 09:42 AM
turnrjr's Avatar
turnrjr
Look close at the spring Abe. The outer end is supposed to be held by the tap. The end of the spring is broken off. Same on both.
If I could find a spring, I’d replace it but seems they’re not available.
Old Mar 6, 2022 | 12:00 PM
bigwin56f100's Avatar
bigwin56f100
There is a set on eBay. I know because they are mine. I'm not allowed per fte guidelines to post a link to my own eBay items
I looked at your pics and they look fine to me as well. The spring isn't really a spring is a cushion to reduce bounce. If they have friction when you move them they are operating correctly
Old Mar 7, 2022 | 05:56 AM
turnrjr's Avatar
turnrjr
Abe and Kevin, I stand corrected. Thanks for setting me straight.
Old Mar 7, 2022 | 07:19 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
If he could post his own adds, it would look a lot like this:
1953 1954 1955 1956 ford truck seat snubbers Original Part F100 Pickup F250 F350 | eBay
But he can't.
As Bigwin said, it looks fine. They don't provide radial resistance like a hood spring, they provide compressive resistance like a suspension spring. It is pressing back against the flat part of the arm.
Old Mar 7, 2022 | 07:30 AM
EffieTrucker
If you find a way to keep the seat from squeaking, let me know.
Old Mar 7, 2022 | 08:19 AM
abe's Avatar
abe
Find the squeek then spray with your favorite lubricant.
austincarnut
May 23, 2023 10:10 PM
austincarnut
Oct 18, 2022 05:35 AM
df85732
May 11, 2016 01:33 PM
awjjim
Jul 13, 2013 11:31 AM
75F100GA
Mar 6, 2007 02:04 PM
