Sponsored by: Kumho
Power steering leak?
Old Mar 5, 2022 | 08:32 AM
unibody62's Avatar
unibody62
I posted this over in the 2009-2014 forum, but thought maybe I could get advice here as well.
So, last spring I had a failure from rusted power steering lines. I replaced every line because they were all starting to look questionable. All good until the other day. My daughter had borrowed my truck, called to say all the PS fluid had leaked out and wouldn’t steer. After towing it home, I had a look see under there. Fluid everywhere, no way to see where it may have come from. I poured in 1/2 quart, and it just poured out, but I couldn't see from where it was coming because of blocked view. After using a fiberoptic scope, I managed to see the general area. It seemed to be coming from the high pressure line off of the pump. I can’t picture the Teflon seal just blowing out like that, so I’m thinking possibly the pump seals have failed. Clearly something has blown out. Which seal is more likely, do pumps fail like this? I’ll probably have to get back out there and add fluid again and pay close attention to the source now that I know the general area, but just asking at this point. Pumps are quite pricey, but the pump needs to come off to even to replace the high pressure seal.
Old Mar 6, 2022 | 09:55 AM
mark a.'s Avatar
mark a.
Was it running when you put the fluid in ?
Old Mar 6, 2022 | 04:21 PM
unibody62's Avatar
unibody62
Not sure about the question, but after I replaced lines last summer, I added fluid and burped out all the air. It worked fine for over 6 months. I did figure out what happened, but don’t really know why it happened. The hose connector blew apart at the pump for some reason. Thinking it may have not been properly seated, I inspected it and pushed it back on (has an internal snap ring). It seemed secure, so I replaced the rubber o-ring behind it as well as the Teflon seal and put it back together. It blew apart again half way through the burping process. I had the wheels off the ground, so there was no drag on the system. I know I can buy new connectors, but I’m afraid that the line may be compromised from coming off twice. I have ordered a replacement line under warranty from Rock-auto. I’m hoping the line replacement goes well, I can’t remember how accessible the connection is on the PS rack.
Old Jun 16, 2022 | 12:03 PM
unibody62's Avatar
unibody62
Originally Posted by alikaka
Typically, leaks in the power steering system occur due to wear and aging of elastomeric (rubber) seals and gaskets (seals). Their wear and tear leads to constant hydraulic fluid leakage and the risk of a leaky system. In addition, I would also advise you to look for a new steering wheel. This article shows the ten best user rated handlebars available on Amazon. It is also important to read the owner's manual carefully to avoid technical problems with the replacement
This was a catastrophic failure of the connector, not due to age as it was only 10 or 11 months old. I’m assuming that the steering wheel advice was just a suggestion and has nothing to do with future or past leaks. The covering on the steering wheel is stated to show its age, but I am just getting a nice leather cover and lace it on.
MOD note: the post quoted here was removed as spamming, but left here for context.
Old Jun 16, 2022 | 06:17 PM
Thunderkiss1965's Avatar
Thunderkiss1965
I think alikaka is a troll
Old Jun 16, 2022 | 06:22 PM
unibody62's Avatar
unibody62
Makes perfect sense, I guess I forget about ppl like that .
unibody62
2009 - 2014 F150
Mar 6, 2022 04:24 PM
LCA078
Feb 27, 2022 11:57 AM
john jamieson
1983 - 2012 Ranger & B-Series
Mar 15, 2016 12:06 PM
grip1968
Apr 30, 2012 09:26 PM
RTM
Jun 26, 2004 07:54 AM
