I have a 2012 F-250 Super Duty with the 6.2L gas engine. Having some issue with starting/cutting out/dash Christmas Tree lights. Any suggestions on a good code reader so I can maybe try to determine what the heck is going on?
I've had good luck with the bluetooth readers on ebay for engine and transmission codes, and most all of them will display real time data while the engine is running.
For something like that, I would check the charging system voltage when it's running, and also battery connections.
