Super duty 2015 6.7l engine codes
Old Jan 18, 2018 | 04:34 PM
Alaiex123's Avatar
Alaiex123
can someone tell what P07E3 check engine code is ??
Old Jan 19, 2018 | 11:23 AM
Ed Allen's Avatar
Ed Allen
Go to this link on Ford150.net.... it has a complete listing of all OBDII codes with a pretty description of what may be causing the DTC.... I'm not sure if there is a code PO7E3. I understand that the DTCs are pretty much standard within the automotive industry.... so you might want to look again at your DTC reading. But that's just me. I am certainly not an expert on codes....I just try to listen and learn.
https://www.fordf150.net/forums/viewtopic.php?t=2621
There was a post there which gave this website....and I have gone to it for a DTC problem I was having on my '12 F250 SuperDuty. I hope this helps you.
Old Jan 19, 2018 | 11:47 PM
Evan_P's Avatar
Evan_P
Double check your code. That is not a valid code for that vehicle. If your using a cheap aftermarket code reader chances are it is kicking out an incorrect code.
Old Jan 20, 2018 | 08:33 AM
senix's Avatar
senix
moved to the 6.7 forum.
Alaiex123
Jan 18, 2018 06:24 PM
ladiabla74
1997 - 2003 F150
Oct 20, 2006 07:10 PM
eric777
Sep 18, 2006 06:55 PM
Keith1984
1997 - 2003 F150
Feb 3, 2004 05:26 PM
