Excursion engine swap
Old Feb 25, 2022 | 11:55 PM
Why-it-so-loud's Avatar
Why-it-so-loud
I got a new v10 excursion but the motor stopped work. I also have a 7.3 4x4 excursion but it was in a rollover however the motor and trans work fine. Should I body swap it or move everything over to the v10? Please don’t tell me it’s easier to just buy a diesel or to just leave it alone. I have to much ambition to discover if it can be done. Thank you
Old Feb 26, 2022 | 12:36 AM
jjmills's Avatar
jjmills
if the v10 is 4x4. deffinately swap motor trans and all wiring/ecm etc. it is a big job but doable.if v10 is rusty might want to reconsider
Old Feb 26, 2022 | 01:29 AM
Why-it-so-loud
the v10 is 2wd. Is it better to swap the body or trans motor ect
Old Feb 26, 2022 | 08:18 AM
wpnaes's Avatar
wpnaes
It's a big job either way, keep the 4x4 ability and you'll never regret it even if you never use it.
Old Feb 26, 2022 | 11:27 AM
Antonm's Avatar
Antonm
Depends on what shop equipment you have. If you have the ability to safety raise and lower a complete Excursion body, then that makes a big difference. Engines, transmissions, and transfer cases all come apart and can be swapped around between vehicles using a basic engine hoist (available at Harbor Freight for like $200), but lifting a body off the chassis without damaging it requires equipment that most DIY'ers just don't have.
Creekside48
Engine Swaps
Feb 22, 2022 01:33 AM
Kags1969
Nov 28, 2021 11:39 AM
Danben111
Engine Swaps
Feb 24, 2020 01:39 PM
3244don
Aug 28, 2009 12:47 PM
kountzecobra
Jul 5, 2008 09:24 PM
