Cruise control doesn't work. Replaced E-brake switch, checked all fuses. No codes. What else should I look at? Not sure how to trouble shoot this without a code.
What about the clock spring in the wheel or the switch in the brake fluid reservoir?
If the truck is a manual, what about the clutch safety switch?
Do the brakes and lights function as they were designed?
Thank you for the link. I'll read through it tomorrow. My truck is an auto, im not sure about the brake fluid reservoir switch. I did not think of that. Horn and passenger airbag lights work. All brakes and everything else function properly. I had a mechanic suggest a "speed sensor" but there are no codes so I wrote that off.
