Clutch Equalizer
Old Mar 23, 2022 | 10:36 PM
crazy96863's Avatar
crazy96863
You make a good point. I was considering that option. It’d definitely be superior to the original setup. The answer is probably a combination of a few different factors.
I’m resisting the urge to over engineer. This wasn’t perfect but it’s definitely time tested. It continues to perform even when worn beyond recognition. I guess I’m trying to preserve a bit of that.
Cost and time are a factor; I’ve got an entire truck I’m trying to finish. This level of engineering is pretty minimal. It also keeps replacement parts readily available vs having to remanufacture custom parts every time something wears out.
To summarize… probably cost vs reward; money sure but mostly time. I’m trying to get this thing done. It’s been 5-6 years. I’m tired of not having my truck on the road. I can re-attack specific areas once it’s going if further improvements are needed.
Trying to find a balance somewhere between all that with everything I do.
Thank you for your reply. It made me reflect on some things.
Chub Chub
Nov 29, 2019 11:12 AM
82_F100_300Six
Aug 20, 2018 05:36 PM
Clem's Cousin
Sep 6, 2015 01:44 AM
bobpfister
Sep 18, 2014 10:10 PM
jd_sylvia
May 3, 2007 07:42 AM
