Thoughts on adding reverse lights and where is reverse wire?
Old Feb 22, 2022 | 06:58 PM
powerboatr's Avatar
powerboatr
Originally Posted by Ltngdrvr
I have mine on the #1 upfitter, that way I can have them on all the time if I want, not just in reverse.
ME dos
Old Feb 22, 2022 | 10:08 PM
TX Chris's Avatar
TX Chris
Originally Posted by robert sloane
ME dos
After thinking about it more today, I believe I'm going this way as well. I do a lot of city driving and I think simpler may be better in this case.
Old Feb 23, 2022 | 04:14 AM
4B11TX's Avatar
4B11TX
Originally Posted by TX Chris
Thanks for that! Would you mind providing a link to the thread?
There is a PFD file attached to the post above yours.
Old Feb 23, 2022 | 07:54 AM
bigred460ci's Avatar
bigred460ci
Mine will come on in reverse or via upfitter. For me I only really need them to come on in reverse in the winter when I'm plowing. So I installed a switch behind the bumper so I can disable the reverse feature for the warmer months and if I need them on I can use the upfitter switch.
Old Feb 23, 2022 | 06:43 PM
blfuller123's Avatar
blfuller123
Trailering
I just ordered a pair of the f150 LED lights. I will wire these so the lights on normally when the reverse lights are on but I will be able to turn them off with the upfitter switch when I want them off.
I am wiring them directly to the trailer reverse circuit and I will use a 5 pin relay with the NC circuit to open and close the ground with upfitter switch as the signal.
Old Feb 24, 2022 | 10:00 AM
mewaschuk's Avatar
mewaschuk
you can make an auto-manual circuit with a 5 pin relay...
just added reverse/puddle lights that are auto on with unlock/door open + auto on in reverse + manual on with aux 👍
Old Feb 24, 2022 | 05:18 PM
blfuller123
Trailering
Here is how I am doing mine
Old Feb 24, 2022 | 08:14 PM
Texasguy2017's Avatar
Texasguy2017
Use a relay or install a diode in between to use both the reverse circuit and a switch.
Sean Roth
Apr 17, 2021 11:35 PM
ssande
Jun 22, 2017 10:20 AM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
RussF350
Feb 9, 2011 03:59 PM
GrampsHandMeDown
2004 - 2008 F150
Dec 27, 2008 10:49 AM
