No Reverse Lights
Old Apr 16, 2021 | 12:22 AM
Sean Roth's Avatar
Sean Roth
4wd Low
No Reverse Lights
1995 f250 5.8L - Having an issue with my reverse lights. Spliced in some LED puck lights with my reverse lights and kept blowing fuses so I took them out. Now I've got no power to the stock reverse lights. I have power to the fuse holder and to the transmission switch and the rest of the wiring looks good to the reverse lights. I noticed a few of my grounding straps were almost broken and the one from cab to chassis was torn right through. Could this be a part of the issue? Any Ideas?
Thanks!
Old Apr 17, 2021 | 09:32 PM
marksman76's Avatar
marksman76
Are you looking in fuse box inside the cab, or in engine compartment?
I had same problem and the correct fuse was in engine compartment
Old Apr 17, 2021 | 11:35 PM
Sean Roth's Avatar
Sean Roth
4wd Low
It's inside the engine bay, fuse E 15amp which the 5th one up from the bottom left. I'm thinking I have a short somewhere but I'm having a heck of a time finding it.
ssande
Jun 22, 2017 10:20 AM
drawtiteboy2
2004 - 2008 F150
Dec 17, 2014 05:47 AM
sjguy105
Mar 26, 2012 08:48 PM
AMEC Electric LLC
6.7L Power Stroke Diesel
May 16, 2011 09:28 PM
GrampsHandMeDown
2004 - 2008 F150
Dec 27, 2008 10:49 AM
