Sponsored by: Real Truck
Power Outlets Went Out
Old Feb 20, 2022 | 08:31 PM
Jim McCarty's Avatar
Jim McCarty
Unusual problem. All five of my 12V power outlets went out at once. I’ve researched everything I can think of but nothing comes up. Any suggestions?
Old Feb 20, 2022 | 09:29 PM
62fordF250's Avatar
62fordF250
With electrical issues, always start at the power source. Battery and connections good? Fuses good? Relays good? Wiring good? Component good?
Most new vehicles' power outlets are switched on and off by a computer. Without the wiring diagram I couldn't tell you which one, which fuse(s) or which relay(s) control the power outlets.
Any recent changes or additions to the pickup? What happened right before they quit?
Old Feb 21, 2022 | 06:10 AM
projectSHO89's Avatar
projectSHO89
Assuming the 06 F350 in your signature. If something else, it is necessary for you to explicitly identify the subject vehicle and to ignore the following as it won't apply to newer models.
The factory diagrams show the 06 SD only has a single power point plus the cigar lighter. Those are run off CJB fuses F04 and F12 respectively.
I'd have to assume that the additional power points were added after the truck left the factory. If so, the additional points may have spliced into one of those original sources so check their fuses first. If they are okay, then look for additional circuits which may have been added, possibly through the upfitter's circuits.
Nothing computerized about these circuits on this truck, that concern can be removed.
Old Feb 21, 2022 | 01:28 PM
Jim McCarty
Oops. This truck is my 2014 F250 diesel. It has five outlets and all five have separate fuses. All five went out simultaneously.
Old Feb 21, 2022 | 02:27 PM
projectSHO89
Does the cigar lighter work or not?
Have you checked for ALWAYS HOT power to the respective fuses in the fusebox?
And what happened to cause (or cause to be recognized) that "simultaneous" failure? Given the way the circuits are spread across multiple fuses, connectors, grounds and harnesses, it would seem highly unlikely that such an event would occur. Not impossible, but HIGHLY unlikely as that would require multiple simultaneous failures. Have you considered that whatever you're using to test the outlets my not be working?
Old Feb 21, 2022 | 07:35 PM
kehinnc's Avatar
kehinnc
Did you have anything plugged into any of the 5 power points when they went out?
badpaddler
Oct 16, 2021 08:07 PM
ColeFix
Apr 29, 2021 01:58 PM
dablack
Oct 20, 2018 06:00 PM
NVRAGN
Sep 22, 2009 08:57 PM
BLiTzNicK
2004 - 2008 F150
Mar 29, 2004 11:45 PM
