engine blocks
Old Nov 6, 2003 | 12:09 PM
Perrogrande's Avatar
Perrogrande
engine blocks
Hello all. I am new here and I have a 1985 F150. The truck has been parked for about a year when I had to move it. I put a new battery in it and used some ether in it and after about 10 mins it finally started. I was elated. Then I noticed that it was running hot so I took it to the water hose and started filling the radiator and noticed that as fast as I was putting the water in it was pouring out the passenger side of the motor. It appears to be a busted block. Is there any place online that I can find a block to replace the one I have. Also what would I be looking as far as the cost. I have tried searches and I find rebuilt motors all over, but I can't find just the blocks. BTW the searches is how I found this site.
Old Nov 6, 2003 | 12:24 PM
95BlackF150's Avatar
95BlackF150
wut bout freeze plugs check them see if its running down blocks shouldn't crack unless you stored it and it full of water
Old Nov 6, 2003 | 12:29 PM
Perrogrande
You made a good point. I didn't think of that, but I will check it out.
Thanks
Snowturtle
Sep 27, 2012 09:37 AM
arrowheadfred
1997 - 2003 F150
Sep 13, 2012 10:50 PM
fastphil
Apr 21, 2010 04:21 PM
f350custom
48
Feb 17, 2009 10:22 PM
bluesky636
Sep 6, 2004 07:09 PM
