Oil Bath Breather....
Old Apr 21, 2010 | 09:27 AM
fastphil's Avatar
fastphil
Anyone know where I can find an oil bath breather for my '54 Ford F100 239 Y block motor? I've searched the internet and can't find anything. Also, would it be ok to sandblast the one I have (had some water get in it), if so, what about the inner mesh? Thanks in advance.
Last edited by fastphil; Apr 21, 2010 at 11:34 AM. Reason: forgot to ask another question...lol
Old Apr 21, 2010 | 02:03 PM
Julies Cool F1's Avatar
Julies Cool F1
Well, you may find on eon e-bay.
I might try chemical rust removal on that. Here's a few links:
Rust Removal From Steel
https://www.ford-trucks.com/forums/5...t-removal.html
Old Apr 21, 2010 | 02:12 PM
fastphil's Avatar
fastphil
Thanks Julie.....I give it a shot. Mine's not in really bad shape, it's just had some water in it and has a little rust. If I can get the inside clean, I'll paint the outside, add a little oil, and it should be ready to go. Thanks again!!
Old Apr 21, 2010 | 03:39 PM
Julies Cool F1
That reminds me. If you can kill the rust, and get it clean, you can coat the inside with shellac - same as a gas tank - to seal it.
You may want to consider contacting your local motorcycle shop and ask them for a gas tank "sealing kit." It will have a chemical acid to kill the rust, denatured alcohol to clean it, and the "magic coating" (white pigmented shellac) to seal it up. Or go to the POR-15 website and look at their gas tank sealing products - would work perfect for an oil bath!
Old Apr 21, 2010 | 04:21 PM
fastphil's Avatar
fastphil
Thanks Julie, you're a great help!!
2zwudz
Nov 20, 2013 04:29 PM
52 daddy's girl
Jun 17, 2013 09:11 PM
homade
Oct 22, 2011 05:57 AM
bobby464
Oct 17, 2011 12:43 PM
dan in texas
Aug 2, 2002 11:21 AM
