Jack Stand Safety Question
Old Feb 18, 2022 | 09:33 AM
jasonodsky's Avatar
jasonodsky
How do you guys jack up your rig and then transition to supporting the axles with jack stands? Seems to me the jack is always in the way of the intended point where I want to place the jack stand (under or near the leaf spring). I'm asking for when I'm doing wheel and axle work where the suspension remains under the vehicle's own weight, not for getting the frame on jack stands. Was wondering if there is a trick or technique you guys would recommend.
Thanks,
Jasonodsky
Old Feb 18, 2022 | 10:27 AM
pirate4x4_camo's Avatar
pirate4x4_camo
in the rear I I put the jack under the pumpkin and lift both sides, stands under the axle out as far as practical
in the front I jack in the center of the axle just next to the pumpkin and put the stands out next to the C yokes.
if you have the stock stamped steel cover you will want to either trim it or use a block of wood to keep from contacting the cover or it can bend and leak.
Old Feb 18, 2022 | 01:14 PM
WE3ZS's Avatar
WE3ZS
^^^ Same ^^^
Old Feb 18, 2022 | 02:27 PM
jasonodsky's Avatar
jasonodsky
I have heard doing that could risk bending the axle housing because they're not designed to handle the weight of the truck on the pumpkin. You have a lot of experience with suspension and axles so I trust you guidance. Could you explain further so I can get a better understanding of why it really is okay?
Thanks,
Jasonodsky
Old Feb 18, 2022 | 04:58 PM
Dweber85rc's Avatar
Dweber85rc
Perhaps if you were using that as the only lift poi t and keeping it that way for an extended period I could see that as being a valid concern. But for a 30 seconds it takes to lift and place a jack stands I would not worry about it.
Old Feb 18, 2022 | 07:31 PM
bluovl's Avatar
bluovl
I use a Hoffman Mini Lift. It's a single post lift that picks up the vehicle at the wheel. You then place a stand or stands wherever you want. I try not to lift at the pumpkin. I would post pictures, but the site doesn't like the HEIC format, and I haven't figured out how to convert photos back to JPEG.
Old Feb 18, 2022 | 09:48 PM
pirate4x4_camo
Thanks,
Jasonodsky
i have never heard this but it sounds like internet nonsense.
my guess is someone figure that because the rear axle weigh rating is 5250 lbs and it normally supports the vehicle in 2 points each support point can only handle 2650 lbs. the problem with that line of thinking is this is static, If you go jump your EX off a curb or hit a pot hole at at 60mph your axle load is higher by a magnitude speed x distance and yet it doesn’t bend.
normally we use heat when straightening and a 20 ton jack, Without a gauge I don’t know how many tons it actually take but a good bit more than 3.
pic is straightened a bent tube which is where the actually bend when you bottom out.
yes I’ve also chained each end and jacked under the pumpkin. Just don’t have a pic of it.
anyhow, now you have my curiosity do I’m gonna need to find out the number.
Old Feb 19, 2022 | 06:23 PM
jasonodsky's Avatar
jasonodsky
Thanks @pirate4x4_camo I'm curious to know what you find out too. I appreciate your real world experience and willingness to share it here. I'll stop worrying about jacking on the pumpkin and chalk it up to internet nonsense.
Cheers,
Jasonodsky
Old Feb 19, 2022 | 06:24 PM
jasonodsky's Avatar
jasonodsky
That's a snazzy tool! Pricy but now I know to start watching for one to show up on Craigslist.
Thanks,
Jasonodsky
Old Feb 19, 2022 | 10:58 PM
bluovl's Avatar
bluovl
It is pricey, but very handy. I used it move around those 6-7 hundred pounds differentials. Either I'm getting older, or these parts are gaining weight. 2 of them would be slick. I know I have read in Ford shop manual somewhere not to use the differential as a lifting point.
Old Feb 20, 2022 | 08:06 AM
Smoothwater's Avatar
Smoothwater
Floor jack and 6 tonjack stands here. Had it on the 6 tons on the axles for 2 months with no issues when Project Scurvy first came home. Hoping to add a 4 post though now that we goy plenty of space at the new homestead.
P4IN COMM4NDO
16
Sep 26, 2016 12:02 PM
speakerfritz
Apr 27, 2015 11:29 PM
jspence105
Nov 11, 2012 11:04 AM
cwgoff
1997 - 2003 F150
Jul 12, 2004 08:40 PM
lexluthr69
Oct 13, 2003 10:57 AM
