Cruise control button relocation question...
Old Jun 17, 2010 | 08:15 AM
KINGSIZex's Avatar
KINGSIZex
Question Cruise control button relocation question...
I would like to relocate my cruise control buttons onto the dash so that I can replace my cheesy factory steering wheel with a nice custom unit. I realize I'll be losing my airbag mounted in the current cheese-mo-wheel, but I am willing to do that in order to install a wheel with a much better feel to it. Mine is shot and the covers don't work for me. Anybody make this mod? Any ideas, tips about wiring, etc would be greatly appreciated.
Steve K
03 Excursion EB, 6.0 PSD,
6" Pro comp, 4" Turbo back, SCT, EGR disable, 35" BFG's on 20's, Pro comp dual steering damper, etc.
Old Jun 17, 2010 | 08:22 AM
DRM's Avatar
DRM
Are you wanting to relocate the OEM switches, or go with entirely new switches?
Old Jun 17, 2010 | 08:57 AM
KINGSIZex's Avatar
KINGSIZex
I'm open to either I guess. I'd just like the cost to be reasonable. Any ideas?
Old Jun 17, 2010 | 10:07 AM
jdadamsjr's Avatar
jdadamsjr
I relocated mine....
It fell off I used it so much
Seriously.... still works, but the rocker button mount broke and it fell on the floor board !
Heard Lincoln Navigator or Aviator wheels will fit....
U might take a few moments to do a search for that on the forum.... seems like I recall some threads... good luck....
Old Jun 17, 2010 | 03:28 PM
UrbanXX's Avatar
UrbanXX
Sorry to offer a negative response, but I would advise aganist this.
Reason: The cruise control works off the clock spring in the steering column.
As others have noted a Navigator steering wheel will work and they look pretty darn good also you don't loose your air bag.
Old Feb 20, 2022 | 12:31 PM
corycartman's Avatar
corycartman
Cruise Control Switch Relocate Problems
I’m just wondering if anyone can help me, I have an 89 F-150 I’m guessing it’s very similar and I’ve tried what you have suggested but it’s still not working. I’m really struggling here and desperately need some help, I am attempting to relocate my cruise control I have tried numerous times and I swear I have everything wired correctly but it’s not working, when I hit the cruise off button the horn sounds and the cruise will not work, I’ve done extensive searching on forums but I cannot find the answer, I have read people having the problem and what they did to fix it so I’ve tried those fixes but still with the same results. I tapped the yellow wire at the connector below the steering column and ran it to the two yellow wires on the cruise control switches. I tapped the purple wire at the connector and ran it to the purple wire on the cruise control switch as well as one end of the horn pad. I tapped the black wire at the connector and ran it to both black wires on the cruise control switches and another wire to the other horn pad. I swear this is how it was connected at the start and how I have read to connect it but yet no results. Please please please help me!
Bansheesandrider
Feb 20, 2022 12:34 PM
bhmayor
Apr 17, 2017 07:51 AM
mgoolsby
Feb 24, 2017 08:35 AM
J_Bowers04
Mar 17, 2008 08:14 PM
vwhed1979
Aerostar
Jan 20, 2006 11:24 AM
