Headlight problem
Old Feb 17, 2022 | 11:59 PM
apellervo2's Avatar
apellervo2
Headlight problem
My headlights quit working on my 97 f350. High beams work when I pull it towards me. But if I push switch forward my highbeam light won't come on. My low beam doesn't work either. All my fuses are good and i replaced the switch with a new one and still the same problem. Where is the headlight relay located? iv asked everyone i know and nobody knows.
Old Feb 18, 2022 | 04:30 AM
tjc transport's Avatar
tjc transport
i ain't rite
have you checked the bulbs? it is not uncommon for them to both burn out at the same time.
Old Feb 18, 2022 | 06:35 AM
Hit Man X's Avatar
Hit Man X
No relay, power runs direct to from batts to switch to bulbs.
Just disconnect the connector to the headlight bulb, flip them on in the cab, check for voltage. This is very easy to test, you are way over thinking it.
I too have seen both fail at same time.
Old Feb 18, 2022 | 10:23 AM
Edgethis's Avatar
Edgethis
Check the headlight socket for power as mentioned. That should help narrow down any issues.
The multifunction switch (the arm on the steering column) can go back and could cause the high beam issue.
Obviously make sure the bulbs are good too. These trucks didn't have a relay for the headlights from the factory. It is a good upgrade though to add.
Old Feb 18, 2022 | 11:14 AM
apellervo2's Avatar
apellervo2
yes i checked the lights
Old Feb 18, 2022 | 11:17 AM
Hit Man X's Avatar
Hit Man X
How did you check them?
Old Feb 18, 2022 | 11:24 AM
apellervo2's Avatar
apellervo2
thank you all for the input I really appreciate it
Old Feb 18, 2022 | 11:26 AM
apellervo2's Avatar
apellervo2
i put them in another truck and they work, i also tried another set of new light and they didn't work either
Old Feb 18, 2022 | 11:41 AM
Hit Man X's Avatar
Hit Man X
Thumbs up
Gotcha.
Well I would trace powerflow from the headlight switch or the combo switch as Edgethis pointed out.
Old Feb 18, 2022 | 01:01 PM
tjc transport
i ain't rite
You said you replaced "the switch"
which one, the one in the dash or the one in the steering column?
the one in the dash turns the lights on/off.
the one in the column is the one you need to test or change.
Jamey Eaton
22
Oct 12, 2021 01:49 AM
karjunkie
Feb 18, 2014 12:25 PM
eman resu
Electrical Systems/Wiring
Feb 20, 2007 08:56 PM
duhlry
Aerostar
13
Mar 20, 2005 11:03 PM
Tattoo Matt
Oct 27, 2003 11:41 AM
