GLow plug led mod
Old Nov 10, 2025 | 08:49 AM
Kwikkordead's Avatar
Kwikkordead
I went super K.I.S.S. on my truck. No light, just a momentary "ON" push-button starter switch purchased from NAPA many years ago that grounds out the terminal that normally goes to the PCM to command the glow plugs to power up. I know that it all is still working because the dome light slightly dims down when I push the button to activate the glow plug relay. So I don't really need a light to know if the glow plugs are powered or not, LOL.
In the years past, the glow plug's only function in life was to provide enough heat to the combustion chamber to get the fuel injected to reach that temperature thresh hold enough to ignite and get the engine to run. Nothing more. So I've adapted a long term strategy to keep the glow plugs from burning out due to over-use just to try and control smoke on an engine that makes smoke during normal engine operation.
Old Nov 11, 2025 | 12:07 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
I like the simplicity of commanding on when needed.
But I have a GPCM so...
Old Nov 11, 2025 | 07:01 AM
Kwikkordead
Gotta love California.
Old Nov 11, 2025 | 01:58 PM
knottyrope's Avatar
knottyrope
GPR light can light up and GPs not be on...........
I had enough grime on my GP wire terminals that they wouldnt work yet I had 12 volts on the post.
scotch brite pad and a few good rubs and it was working like it should
its just another IDI Off Topic light
Old Nov 11, 2025 | 02:52 PM
Big Horn 2's Avatar
Big Horn 2
I’ve had my GPR indicator lamp for 7 years, works flawlessly. And when my OEM GPR bit the dust I replaced it with the White Rodgers - only way to go IMHO.
Old Nov 11, 2025 | 03:35 PM
SteveH-CO's Avatar
SteveH-CO
I have a below-dash voltmeter and just watch the voltage dive when I turn on the ignition. It's plenty of indication that the glow plugs are working.
crstewart60
Dec 27, 2011 12:41 PM
brian42
22
Jan 2, 2011 08:20 AM
Spool&Go
16
Jul 29, 2010 06:29 PM
bearhugger
Apr 24, 2010 09:15 PM
WALJON
Oct 14, 2007 12:42 AM
