Squeeling like a pig
Old Feb 14, 2022 | 01:11 PM
jrotten67's Avatar
jrotten67
My truck, a 78 F150 4.9 NP435/ 205 has developed a squeal. I do have a 3G on it and thought that's what it was. I replaced the belt and it did not stop. It doesn't squeal all the time. It comes and goes. Today it squealed longer than it ever has. About 3 miles worth. It squeals mainly at low RPMs. It will start suddenly and end just as fast. It does not seem to change with RPMs. I filled PS pump. Changed both it and the 3Gs belt. What else could it be?
Old Feb 14, 2022 | 03:34 PM
Ozzie H.'s Avatar
Ozzie H.
It could be many things. If there are other belts, it could be one of them. It could be a bearing in the alternator or water pump or power steering pump. Try some of that anti-squeal belt treatment. Loosen each belt one at a time briefly to see if it stops.
Old Feb 14, 2022 | 04:31 PM
Saluki_guy's Avatar
Saluki_guy
Army trick. Throw talcum powder on the belt. Will kill a squealing belt noise if that is it.
Old Feb 14, 2022 | 05:02 PM
FuzzFace2's Avatar
FuzzFace2
I think each belt dose the water pump so you could pull the ALT belt and run the motor.
It would be a little harder for the PS pump but could also be done the same way.
If you have AC just unplug the compressor so it cant run and the belt just free wheels.
Dave ----
Old Feb 14, 2022 | 05:10 PM
john jamieson's Avatar
john jamieson
I have a 240 that had a squeal that would come and go. It ended up being a couple of loose manifold bolts that were causing a vacuum leak, when things warmed up.
Old Feb 14, 2022 | 06:23 PM
jrotten67's Avatar
jrotten67
I believe I found it. It finally started to squeal when I pulled in the drive tonight. It's the actual alternator. It came from the junkyard and I knew it was gonna be shortlived because the copper the brushes run on were grooved pretty deep. Looks like it has finally given up. Thanks for all the replies.
kuskye25
Mar 13, 2008 07:02 PM
87carbed
Mar 11, 2005 05:35 PM
Green Meanie 85
1978 - 1996 Big Bronco
Dec 1, 2004 07:17 PM
mrogers
Sep 13, 2004 04:08 PM
88_150
Feb 11, 2003 09:25 PM
