squealing belts
Old Mar 6, 2005 | 01:56 AM
87carbed's Avatar
87carbed
Exclamation squealing belts
whenever my truck gets into the high rpms, in any gear, i get this horrible squeal from my belts, and it is way annoying. can anybody PLEASE tell me what this is?! thanks...
Old Mar 6, 2005 | 12:56 PM
monsterbaby's Avatar
monsterbaby
probably worn or loose belts check for proper tension, and if they appear worn replace them.
Old Mar 6, 2005 | 03:26 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
my power steering belt does that at high rpms, ive replaced the belt numerous times and tightened it so tight i was afraid of damaging the water pump bearings....basically all i did was put another new belt on it, tighten it till there is only about a 1/2" of slack, and put some belt dressing on it from the parts store.....its not as bad now, under normal driving i never hear it, but when im racing someone it will squeal at around 4500 rpms, i just make sure the belt is in good shape and only bring the rpms up that high occasionaly...... just remember, if you loose power steering suddenly, youve also lost your water pump as well..........
Old Mar 6, 2005 | 03:46 PM
87carbed's Avatar
87carbed
that would make sense, because one time, when i was racing, haha, my belts were squealing really bad, and i just decided to ignore it, seconds later my p/s pump basically exploded on me...
Old Mar 6, 2005 | 03:57 PM
stans's Avatar
stans
A squealing belt can certainly be the sound of impending doom. I once had the tensioner pulley on the airconditioner belt lock up, talk about squeal? Man, was it ever loud! So a squealing belt can be the sign of excessive friction between the belt and a pulley. I can certainly see the shaft bearings in a water pump, power steering pump, or alternator failing and causing the pulley to drag against the belt and squeal. It can also be the sign of glazed and worn belts. Of course, glazing can be caused by excessive drag against a pulley.
Old Mar 6, 2005 | 11:08 PM
Bubba Blue's Avatar
Bubba Blue
What STAN said, mine was the PS pump, changed it out, no more problem.
Old Mar 7, 2005 | 05:21 PM
troyski76's Avatar
troyski76
My belts squeal a slow speed 5-10 mph I changed the serpintine belt and still squeals. I suspect the PS pump. How free should the pulley be on the PS pump? thanks do I have to change the pump or can i just grease some bearings?
Old Mar 7, 2005 | 07:22 PM
stans's Avatar
stans
My experience was on an old Torino, but on that car there was nothing to grease on the alternator, water pump, air conditioner, or power steering pump. Generally speaking, the bearings are lubricated and sealed at the factory, when they wear out, they are just simply gone and you either rebuild the belt driven component yourself or go out and buy another one.
Speaking of such things, after three failed rebuilt alternators I learned how to buy a rebuild kit and do it myself. Ended up with an alternator that cranked out out more amps and was extremely reliable.
Old Mar 7, 2005 | 09:13 PM
SwOkcOffRoader
usually the first thing to go on serpentine setups is the tensioner pulley, they can squeal and sound kinda like a belt slipping........
Old Mar 8, 2005 | 03:59 PM
Piffery1's Avatar
Piffery1
Had this problem on a '67 Ranchero with small V8. Couldn't stop the squeal at high RPM with new belts, dressing, overtightening belts, etc. Replaced the alternator pully with a 1" larger diameter pully and never again had a problem.
Piffery1
Old Mar 11, 2005 | 03:52 PM
KenFromNorCA's Avatar
KenFromNorCA
If everything is stock on your engine then you can safely assume the vehicle left the factory with the belts quiet. So how to get them quiet?
Take off the belts and throw them away. No matter how old they are they will not get quiet again no matter how much you clean them. Get some spray brake cleaner and a small wire brush and clean all the engine and accessory pulleys thoroughly. Get down in the grooves and get all the gunk out. Next check the pulley runouts...are they running true? Check the belt tensioner....is it sloppy? Replace it if it is. Then get new good quality belts and install them. NEVER use belt dressing. It will only solve the problem temporarily and cause you more squeeling problems because it pics up road contaminants and forms more gunk on the pulleys.
Old Mar 11, 2005 | 05:35 PM
Piffery1's Avatar
Piffery1
Ken,
My '67 Ranchero (bought new) would usually go 2500 to 3500 miles on an alternator belt before squealing started. Usually started when downshifting into "passing gear" at highway speeds, then get progressively worse with time. Belts replaced by dealer mechanics 3 times under warranty with explanation "lots of them do that". I think it was a design problem. I'm pretty sure later year Fairlanes and Falcons used two alternator belts. I wouldn't assume everything that comes from the factory is ok; look at how many recalls and service bulletins come out every year.
I throughly agree with your maintenance recommendations. I've had two serpentine belt tensioner spring failures (one broken, one weak) that caused squeals.
Piffery1
