8BA teardowm
Old Feb 5, 2022 | 07:23 PM
tip49's Avatar
tip49
8BA teardowm
Look what followed me home today.
I have low hopes this 8BA engine will prove to be rebuildable but I will tear it down and see what I find. It will be a good learning exercise and parts will be saved, if nothing else.
It is very complete and original except for the Aluminum intake manifold.
I picked it up this morning and started chiseling off, literally, the crud and baked on grease and oil. I got the plugs out, and have the cylinders basting in ATF.
I will see if it will free up but I am going to tear it completely down regardless. The condition of the block is my prime concern. Good money after bad? Possibly, but onward McDuff!
Oh, and a transmission too, bonus.
Old Feb 5, 2022 | 09:38 PM
56panelford's Avatar
56panelford
The aluminum intake should be factory shouldn't it..
Old Feb 5, 2022 | 10:29 PM
Steve Harlow's Avatar
Steve Harlow
Put it in a fourth gen camaro or firebird. Restore some balance in the world with the anti LS swap.
Old Feb 5, 2022 | 10:37 PM
tip49's Avatar
tip49
possibly I always thought they were cast iron but my knowledge of Flatheads is slim and next to nothing.
Old Feb 5, 2022 | 10:56 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Canadian flatheads in a certain period (49 - 51?) came with aluminum manifolds, on both Fords and Mercs. Some Mercs had aluminum manifolds for a square base Holley carb. I have run both. They weigh about 15 lbs less than the cast iron ones.
Fingers crossed on the block! Looks like a nice score! Is that a 3-sp?
Old Feb 5, 2022 | 11:25 PM
tip49's Avatar
tip49
Fingers crossed on the block! Looks like a nice score! Is that a 3-sp?[/QUOTE]
Engine came out of a 48, M68 Merc truck, yes 3 speed seems to go into all gears. Lost another 15 lbs without caked on grease and oil.
Old Feb 6, 2022 | 02:49 AM
fish pond's Avatar
fish pond
Nice find,I see its a Merc. via the larger oil filter, my 51 M3 came to me with one as well,along with a alum. intake.
always thought it was stk., straight from a barn in Canada .
I am in process of assembling front axle assm. and the Timken wheel bearings says "made in Canada" very happy about that.
Good luck with your new motor!
Greg
Old Feb 6, 2022 | 09:57 AM
tip49's Avatar
tip49
Greg
I start spring and axle installs today, as soon as I get this beast unloaded.
Old Feb 6, 2022 | 01:18 PM
1952henry's Avatar
1952henry
Air cleaner still attached is a plus, not a guarantee, but a plus.
Old Feb 6, 2022 | 06:40 PM
tip49's Avatar
tip49
Time will tell
I will start total teardown in about a month;
we'll see what nastiness I uncover then. For now waiting on things to loosen up some.
Old Feb 6, 2022 | 06:47 PM
tip49's Avatar
tip49
Time will tell
Don't have high expectstions on the block but I have it unloaded and resting quietly in front of my garage marinating.
Old Feb 7, 2022 | 08:09 PM
38 coupe's Avatar
38 coupe
Please post pictures of the transmission. Since the combo is out of a M-68 it is very unlikely that it is a light duty three speed. Probably it is a heavy duty three (which are not all that common either) or most likely a crash box four speed. If it is a three and you don't plan on using it, someone on hear probably will want it.
Old Feb 7, 2022 | 08:33 PM
tip49's Avatar
tip49
Transmission identity
I will take more photos of the transmission tomorrow . I'm not sure what direction I'm headed at this stage.
Old Feb 8, 2022 | 11:52 AM
tip49's Avatar
tip49
Trans ID
Here are a couple pics of the transmission.
Old Feb 8, 2022 | 02:28 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Looks like a 4-sp crashbox to me, from a larger truck. If not cracked, the rear mount (bearing retainer) may be worth more than the whole trans.
