00 excursion wired noise and vibration
Old Feb 4, 2022 | 09:07 AM
mccloudfam1's Avatar
mccloudfam1
Recently I broke the driver rear shock mount causing an awful hmmm noise and vibration after 45 mph. Had to drive a day like that and then fixed it. Now between 40-50 mph when I let off the gas or put it in neutral it sounds and feels like I am driving on the bumps on tthe shoulder. After 50 it is not as bad but still there. Like I said it doesn’t do it when on the gas just letting off and even does it in neutral coasting. Does anybody have any thoughts on fixing this?
Old Feb 4, 2022 | 02:52 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Does the noise appear to be coming from the same area as the failed shock mount?
Have you gotten under the vehicle to inspect and shake everything you could put your hands on?
At this point, everything is suspect from an exhaust hanger to U-joints to loose caliper to axle bearings.
Old Feb 4, 2022 | 05:16 PM
mccloudfam1
Yes it is definitely in the rear. I looked everything over real good when I was under it but I will check the brakes and bearings this weekend.
Old Feb 4, 2022 | 08:43 PM
udsuth78's Avatar
udsuth78
Upper or lower mount? The lower being basically just a u-bolt and bracket it's pretty easy for them to get out of whack. Any idea what may have caused the mount to break? Old and rusty, previous collision, those kinds of things? Had a look for missing wheel weights yet or tread/sidewall damage
Old Feb 5, 2022 | 03:10 PM
mccloudfam1
It was the little bar at the top that goes through the top of the shock. I was going to rotate the tires when I checked the brakes and see if it is moves
ncuffin
1997 - 2003 F150
Mar 2, 2024 10:19 PM
deadbear
Apr 4, 2007 09:07 AM
superpelly
Nov 26, 2006 10:30 AM
ham4ever
Dec 14, 2004 09:37 AM
