Sponsored by: Auxito
vibration noise
Old Mar 15, 2007 | 12:43 PM
ncuffin's Avatar
ncuffin
vibration noise
I have a 1998 F150 with about 150K miles on it. It is an 8 cylinder 4x4. If I drive down the road say at 65 mph I hear nothing until I take my foot off of the gas. I feel a vibration, and hear slight vibration noise. It is nothing that shakes the truck but I can feel and hear the vibration. As soon as I apply my foot to the gas and speed up the vibration goes away. If I let the truck slow down another 2 or 3 mph the vibration goes away also. It occurs at any consistant speed above 50 mph. It is not real loud and does not shake the truck but I can feel and hear the vibration and I think it is getting worse. My question is if it is transmission or drive shaft related. I am not sure it I should take it to a transmission guy or a general mechanic.
Thanks
Old Mar 15, 2007 | 11:30 PM
Racerguy's Avatar
Racerguy
I would start by checking the U-joints. If you remove the rear driveshaft you'll be able to feel for a loose or a seized joint.
If that's not it then the next likely culprit would be bad bearings in the rear diff.
Old Mar 2, 2024 | 10:19 PM
JB86f150's Avatar
JB86f150
5th Gear
where is it coming from is it coming from the rear or under the floor near the firewall
SkyGamerA320
Dec 13, 2024 06:05 AM
Towmanjbo
Jul 17, 2015 07:23 PM
jjoel
Jun 11, 2010 06:24 PM
ultramax21
2004 - 2008 F150
Jul 27, 2004 10:35 PM
Outpost22
Jan 1, 2003 05:24 AM
