So while the so called go to f truck specialists were fixing my wiped cam which lasted 15,000 Km I got them to do a Carb swap as I was sick of trying to get the EFi to run right. It has cost me an arm and leg and its completely unreliable as it cuts out every now and then and when I hold it flat for a bit then take my foot off the peddle the idle drops so low that when I come to an intersection it stalls.
The shop put a in tank fuel pump from an 80s Mitsubishi carburetted engine which has not seemed to work so they put a second one in the engine bay sitting on top of the rocker cover to get enough fuel pressure to get it out of the shop right on Xmas.
this is just a rant as I will eventually work it out but pride in work is just going to **** these days.
Just dropped it off at recommended carb tuning specialist and he couldn't believe the crap work they did.
He has done a number of conversions and puts in a Walbro low pressure pump in tank and said he has no problems.
He was booked out for a month but I think he felt bad for me and my truck.
I should of known about the other place as it was such a mess of a work shop.
After all the stuffing around and money its running very well. Its got some real punch from 3rd gear when overtaking from 40mph.
The cam is the one the shop got me which is a custom grind from a company that went out of business 7yrs ago.
I have no idea whether the cam is a good match but if you take your truck to the shop 4 weeks before xmas with wiped lifters you get what you get and don't get upset.
The cam was from a local engine builder which must of been sitting on the shelf for at least 7yrs. Apparently he said the customer had changed his mind about a lumpy idol.
Well it appears you now have a 351 with a 302 firing order. That isn't a cam I would suggest.. I think it has too much duration for a truck motor with stock heads. How does it run?
It runs well with good power from 2000 rpm but has excessive pinging from 1500 to 2500 rpm under load.
Well that's not really usable then is it. I bet if the timing is retarded enough that it doesn't ping the motor would be a gutless wonder below 3000rpm. Some combination of quench, compression, and timing may work with the cam but what you have now doesn't.
Thanks for that Paul. I can't get a break with this truck, you put your faith in so called experts and this is what I got.
they didn't even tell me the firing order had been changed.
It does seem to ping less with premium fuel but 25c a litre more.
I rang the Camshaft grinder that inherited all the wade cams profiles and he said he could regrind the cam I have in it now to suit the afr 185 heads im going to get. Is that possible?
The lift seems low, how can you add to that?
The lobe lift is increased by grinding the base circle smaller, which creates its own problems. For instance the lifter will sit lower in its bore when on the base circle, and it is harder for it to follow the lobe profile with a smaller base circle. But camshafts have been reground like this for ages.
The hydraulic lifters will accommodate a certain amount of alteration in the camshaft base circle diameter, so possibly no other valve train changes will be required. If they cannot maintain zero lash on the base circle of the cam lobes, however, then indeed longer pushrods will be needed.
Camshaft bearings can be left alone since camshaft regrinding is done on the lobes only, not on the bearing journals.
The problem with regrinding the cam is your duration. When you regrind the cam you can only change the duration and lobe separation by a few degrees. And you have a lot of duration for a truck, even with AFR heads. You're probably better off to find a new cam
You can also weld material onto the lobe and then re-grind it!
