Wheel Offset and Width Help
Old Feb 2, 2022 | 07:31 PM
440 sixpack's Avatar
440 sixpack
So on a '22 f350 with a leveling kit I'm wanting to run 12.50 / 35-20 tires. I don't mind them setting slightly outside the wheel lip moldings but I don't want to see a bunch of tire outside.
In the wheel I'd like to get my offset options in 10" wide 20's are -10, -12 and -25. are any of these going to get me where I want to be without any clearance issues ?
They also make them in 9" width with zero offset or + 10 offset. I'd rather go with 10" if possible.
Old Feb 2, 2022 | 08:08 PM
eberlestock's Avatar
eberlestock
While I waiting for my new duty to arrive I spent quite a bit of time researching this. I found that anything with a negative offset will stick out of the wheel well. I too want to run a 1250 but want a 9" rim. I feel a +12 offset will have about a 1/4" of tread sticking out. A +1 offset would have closer to an inch of tread sticking out. I am not going to run fender flares but rather bulletproof long john mudflaps. A 10" wheel will have the tread sticking out just a hair more.
Old Feb 2, 2022 | 08:24 PM
440 sixpack
Yikes I don't want an inch outside. 1/4' I can live with.
I don't see much in a 10" with positive offset, maybe it's because of clearance. the book says a 12.50 will work on a 9' but it's not ideal. the stock 20" wheel is 9" correct ?
Old Feb 2, 2022 | 08:51 PM
GG386's Avatar
GG386
Been on this since my 22 was ordered a couple months ago
As far as lift, 1-1/2" is all that's needed since the bed has been lowered for 22 (assuming a 35" tire)
From experience, with the previous generation SD's at least, I ran with +20 0ffset on 10" wide rims with no issues although kind of close to the radius arm
The biggest advantage IMHO is the tire was proud of the fender by at most 1/2", keep in mind this is on a factory two-tone paint
The bigger problem is trying to figure what wheel to pull the trigger on, there's alot out there
Old Feb 2, 2022 | 08:52 PM
EssdeeSD's Avatar
EssdeeSD
12.5 on a 9” wheel is fine. I believe stock is 8”
Old Feb 2, 2022 | 08:58 PM
GG386's Avatar
GG386
Absolutely, by using 10's just give you slightly deeper dish is all
Old Feb 2, 2022 | 09:37 PM
MAX4utah's Avatar
MAX4utah
My wheels are 18x9 +12 offset and they stick out about 1/2-3/4”. 37x12.50 tires. They stick out just enough to make my truck extra dirty when it’s wet out. If I did it again, ide look for a +20 offset.
Old Feb 2, 2022 | 10:24 PM
440 sixpack
In the Grid wheel I like a 20x9 with a +15 offset is he most tucked in they make. so from what you're saying that would be close to flush since I have the fender moldings.
Old Feb 2, 2022 | 10:39 PM
MAX4utah's Avatar
MAX4utah
If you have the fender moldings, a +15 would be tucked for sure.
Old Feb 3, 2022 | 09:10 AM
Sonny Crockett's Avatar
Sonny Crockett
12.50 is ideal for a 9. They recommend 9.5 or 10+ for a 13.50 and 15.50. Get a 9 with no less than a +6 or +10 (+12 or +18 even better for what you want) and you won't have much tire sticking out past fenders. Stock wheels are 8 inch. I have 20 x 9 with 37 x12.50 +18 and they stick out maybe 1/2 inch.
Old Feb 3, 2022 | 09:21 AM
kylant's Avatar
kylant
To get what you are after, go with a 9" wide wheel with a positive offset. the lower the offset, the more the wheel/tire will stick out. you can also look at 11.5" wide tires.
the stock 285s on tremor wheels that are 8" wide with +40 offset are nearly flush with the fenders (no flares)
Old Feb 13, 2022 | 09:18 PM
440 sixpack
Not a lot of positive offset options but I found a few I like. of course they're all out of stock like everything else
Old Mar 16, 2025 | 03:20 PM
DCarrVan's Avatar
DCarrVan
-12 mm offset with 18" wheels
I'm looking at a Set that has the -12 mm i thought this made them sit wide over a + offset ?
Old Mar 16, 2025 | 04:05 PM
4wd6.7L's Avatar
4wd6.7L
Correct, the less positive offset, the farther out they sit. A negative offset is not everyone's taste.
Poufiace
Feb 16, 2017 10:45 AM
jvoigt
Jul 23, 2007 11:05 PM
BHoek
2004 - 2008 F150
May 2, 2007 10:29 PM
Wakeboarder141
2004 - 2008 F150
Jan 7, 2007 01:05 PM
