Wheel Backspacing
Old Feb 15, 2017 | 10:50 PM
Poufiace's Avatar
Poufiace
Wheel Backspacing
I'm a little confused about the oe 20" rim spec. They are +40 offset but are they 8´´ or 8.5´´ wide ? In fact i need to know the correct backspacing of the original wheel because i'm planning 22" with 37" on a carli leveling kit and the law here in quebec is very strick and doest allow the tire to exeed the vehicule at all. And i really dislike the look of a big fender flare
if any of you have picture of positive offset wheel with 22´´ and 37" tire it would be appreciated
Old Feb 15, 2017 | 10:54 PM
RainDesert's Avatar
RainDesert
20x8 is the factory spec. I can tell you that you will want the +18mm or +20mm offset wheels. On a 9" wide, that offset will put you just outside the fender.
Google "custom wheel offset" for tons of pics, or here's a link:
https://www.customwheeloffset.com/
Old Feb 16, 2017 | 10:45 AM
oklarado's Avatar
oklarado
I'm getting a 18x9 wheel that's +18 offset, I'm told it'll be flush but the tire will be slightly sticking out. Like RainDesert said you probably need a +20 on a 9" wide wheel to keep it flush.
oklarado
Nov 19, 2016 11:53 PM
acf6
Apr 12, 2013 04:45 PM
Gary Lewis
Dec 13, 2010 03:56 PM
BHoek
2004 - 2008 F150
May 2, 2007 10:29 PM
Nebraska
Nov 18, 2005 11:48 AM
