wheel size
Old May 2, 2007 | 09:19 PM
BHoek's Avatar
BHoek
wheel size
I was talking with a wheel store about putting some 17x10 wheels with 5" backspacing on my 07 f-150. I am planning on putting 33-12.50-17 on. I have the leveling kit on the front, so the 33's would have plenty of clearance. The store says that putting 17x10 would cause rubbing. I thought that was why they have backspacing on the wheels , to eliminate any problems with rubbing. Which one of us is right? Any help would be appreciated.
Old May 2, 2007 | 10:29 PM
Corey872's Avatar
Corey872
Backspacing will help stop rubbing on the frame, but more backspacing does make the wheel/tire swing in a bigger arc, which may mean it hits the fender or bumper. 33's with a 5.5" backspacing on a 9" wheel seems to be pretty common. You are talking about a 5" backspacing which means the wheel is out an additional .5", plus a 10" wheel which means another 1" sticking out - 1.5" total...that is starting to get pretty wide. Maybe someone running this combo will chime in, but I wouldn't be surprised if it did rub a little.
