7.3L / 6.8L V8 Gasoline Engines Discuss the new 7.3 and 6.8L Gasoline V8s
2021 F53 chassis fuel pump relay/fuse locations
Old Feb 1, 2022 | 06:19 PM
slapshot12's Avatar
slapshot12
Does anyone know there the fuel pump relay or any associated fuses are on the new 7.3L F53 chassis? I’m embarrassed to say I nicked a wire with a drill and now the RV will crank but won’t start. I’m hoping I just shorted out a fuse, so I want to check the fuel related relays and fuses. The owner’s manual doesn’t show any specifically for fuel that I could see. The wire was a light blue one in the wire bundle that runs along the passenger side frame rail.
I fixed broken wires and it’s still doing the same thing. Hooked it up to a scanner and got a fuel pump open circuit code. Still can’t find the fuse or relay.
Snakebuilt
May 20, 2018 10:03 PM
renchr56
Oct 2, 2009 06:26 PM
toyota1988
4 Cylinder Engines
29
Jul 10, 2007 06:23 PM
Cruiser11
1983 - 2012 Ranger & B-Series
May 9, 2004 12:39 PM
slammindeuce
Dec 17, 2001 11:21 AM
