1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2006 f350 beeping
Old 01-30-2022, 07:44 AM
DuncanB's Avatar
DuncanB
DuncanB is offline
Trailering
2006 f350 beeping
I have a 2006 f350 6.0 and every time I press on the brake it beeps, I'm thinking this is just a low brake fluid warning beep but I'm not 100% and haven't had time to check the fluid.
Old 01-30-2022, 07:50 AM
manicmechanic007's Avatar
manicmechanic007
manicmechanic007 is online now
Received 1,154 Likes on 1,050 Posts
The beeping should be only from the parking brake (emergency brake)
Make sure it is all the way off and retry it
Old 01-30-2022, 08:35 AM
DuncanB's Avatar
DuncanB
DuncanB is offline
Trailering
IT was all the way off and the dash light was off as well, even pulling back the brake to make sure it didn't stick
Old 01-30-2022, 04:44 PM
manicmechanic007
How loud is the beep?
Have you tracked it down to inside the truck under the dash like it is factory?
Possibly a previous owner installed a backup beeper and wired it to the brakes
Maybe he rode the hell out of the brakes like an old fart and his mechanic installed it?
Find or make time to check the fluid just in case Ford put a beeper on your master cylinder low level indicator without alerting me
Old 01-30-2022, 04:55 PM
DuncanB's Avatar
DuncanB
DuncanB is offline
Trailering
No it's not a back up beeper, I have had the truck since it was brand new and this is the first time it's ever done this. I checked the brake fluid and it is half way between the min and maximum amount for inside that container. I made sure my tow haul was off and parking brake, also made sure trailer brakes where off, my trailer brake connector for the hitch it disconnected from the plug in, thought it might be from that due to salt on the roads so cleaned them out to the best of my ability haven't been able to test if that worked on not.
Old 01-30-2022, 06:43 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
Find the source of the noise and pass that on. Otherwise, all you're going to get is wild guesses.
Old 01-30-2022, 06:48 PM
DuncanB's Avatar
DuncanB
DuncanB is offline
Trailering
Spoiler
Old 01-30-2022, 11:34 PM
62fordF250's Avatar
62fordF250
62fordF250 is offline
If it only happens when a trailer is connected, watch the brake controller for an error message.
Old 01-31-2022, 11:43 AM
Mike1's Avatar
Mike1
Mike1 is offline
Other forums are saying the integrated brake controller is usually the problem with the 2005 / 2006 models. Someone suggested setting your gain to zero and that there's a brake controller reset you can try before replacing the controller. Hope you find the problem.
GrizzlyMan660
Vehicles for Sale
10-23-2013 04:25 PM
Warhippie
03-02-2011 10:00 AM
dieselsmoker
04-15-2010 06:36 AM
stevelsd
09-09-2007 04:12 PM
canadianfordman
Car/truck Buying Advice
03-28-2005 07:38 AM
Quick Reply: 2006 f350 beeping
