3G alternator conversion
Old Jan 29, 2022 | 02:29 PM
Big Green Booger's Avatar
Big Green Booger
My alternator is done so I did some digging and came across these two old post on an alternator upgrade and ability to get rid of the old school voltage regulator. I wanted to throw it out there to see if there are any learning curves not included in these threads. The only thing not adding up is, for me, the unknown of what is being disconnected when the old harness is being removed. Particularly the two black quick connects currently located near the voltage regulator.
https://www.ford-trucks.com/forums/9...g-upgrade.html
http://fullsizebronco.com/forum/showthread.php?t=55169
Old Jan 29, 2022 | 09:52 PM
John89's Avatar
John89
Post up a picture of which connectors your asking about. We did the swap on our 300 about 3-4 years ago and have had no issues. If we can do it, so can you.
The only thing we had to do that was not mentioned in those threads and others, is we had to trim the mounting bracket(upper) and elongate the groove (bottom bracket) for the alternator to get it to move up enough to get the belts tight.
Old Jan 29, 2022 | 10:16 PM
Big Green Booger
I am concerned about the two black connectors on the edge of the dark circle.
Old Jan 30, 2022 | 04:06 AM
aldridgec's Avatar
aldridgec
They're for trucks with electric choke and for the ammeter. Ammeter cant be used with 3g and if you have factory electric choke you'll have to make mods to it by replacing the cover and wiring to switched 12v.
Old Jan 31, 2022 | 10:01 PM
Big Green Booger
change the cover? 12v switch circuit off of the starter relay?
Old Jan 31, 2022 | 10:50 PM
chris989's Avatar
chris989
Booger,,,
i removed all the spaghetti on my 78. I went with a GM,, easy peasy.
https://www.ford-trucks.com/forums/1...regulator.html
Old Feb 1, 2022 | 06:56 AM
mudbogger2's Avatar
mudbogger2
I went with the bronco graveyard 1 wire 3g alternator. Only wire you need going to the alternator is a battery wire. Very simple.
Old Feb 1, 2022 | 12:31 PM
meangreen92's Avatar
meangreen92
The one at the lower right goes to where the positive battery cable connects to the solenoid/starter relay. It looks to have a fusible link, so it is probably the charge wire from the alternator. Not sure about the two connectors - accessory power leads? You can trace their partners in the truck if it's assembled.
The factory choke on the truck was powered by a separate lug/terminal on the factory alternator, which actually provided Alternated Current. I guess the 3Gs don't have that? I've only ever put them in EFI 5.0 Stangs, so there was no choke to deal with...
Aftermarket chokes mostly or all take 12V Direct Current, like the rest of the truck uses.
Old Feb 1, 2022 | 08:44 PM
Big Green Booger
mudd, Cleanest install ever!! very nice
Old Feb 1, 2022 | 08:47 PM
Big Green Booger
Here is my install. Plugged into the red/green of the old connecter. Any issues you guys see? Installed this and no power form the ignition key?
Old Feb 1, 2022 | 08:53 PM
5851a's Avatar
5851a
Ford just used electronic choke cap heat assist. Unless you're talking the 5.0 Holley on the Mustang GT or PI LTDII. If you run your truck without, just little warm up time in certain situations. 90's era vans have a great wiring source on the 4.9's for the 3G's. short compact, built in fuse link and charge sense wire. Late 80's 3.0 base Aerostar vans have a never mentioned 70-amp 3G, smaller than the 1G that bolts in with washer under single pulley. Add a soft start regulator to it for no belt squeal. If you have gauges the amp gauge will be useless. Recommend rocket man conversion to volts meter. F100VO.jpg (800×555) (rccinnovations.com).
Old Feb 1, 2022 | 10:59 PM
nutter3's Avatar
nutter3
Big green booger,
I'm not sure where your electrical issue is, but on the install I just did on my 390, it is very tight on the back of the alternator near the head. I think you will need to clock your alternator case so the wires come out the side instead of begind the alternator.
Keep after it and you'll get it figured out.
Old Feb 2, 2022 | 09:32 PM
Big Green Booger
Bullitt390 posted the below on the original thread on this topic. Is the yellow/blk wire he mentions the one that shared the original quick connect with the red/green coming from the original harness?
Yep...
Red/ Green (or Green/ Red) from the alt to the red/green in the factory harness.
Take the old large gauge Black/ Yellow and tie it into the + side of the solenoid.
Yellow/ White to large power stud on alt.
Alt power wire to + side of solenoid with 175 amp MEGAfuse.
Done! Drink a beer.
Josh
__________________
[img]signaturepics/sigpic18754_4.gif[/img]
2019 F250 Lariat FX4 6.7 Powerstroke Blue Jean Metallic Two Tone
Old Feb 3, 2022 | 07:47 AM
aldridgec's Avatar
aldridgec
do you have OE electric choke? If so you'll need to change it to a 12v one and find an ignition feed for it. The oe cover is not rated for 12v.
The starter solenoid isnt a 12v switched siyrce, just a start source
Old Feb 5, 2022 | 12:10 PM
Big Green Booger
yep, OE. Thank you for the heads up. New cover or seek out a Holley choke?
carlhwv
6.7L Power Stroke Diesel
Nov 14, 2016 04:22 PM
packrat56
15
Sep 28, 2014 10:16 PM
bigred66
Oct 1, 2012 07:21 PM
RANGER589
May 20, 2011 08:40 AM
HillbillyHellcat
Electrical Systems/Wiring
Jul 9, 2004 01:59 PM
