How to clean trailer plug brass blades on truck?
Thanks BigAlsPSD, that makes sense. I don't know how to do that with my trailer plug on my '04, F250. It doesn't seem to come apart like most plugs. Mine has a connector that plugs into back of plug on truck. The 7 pin receptor is epoxied so moisture can't get to were the wires go. This is kind of had to explain. I tried the electrical cleaner with no luck. In fact, the 4 pin plug next to the 7 pin has bluish crud inside of those 4 pins. I don't know how to clean those too.
[QUOTE=BPofMD;11819978]Sometimes a pipe cleaner works with a cleaner such as DeOxIt ..... Or if you can find a small copper connector. A good electronic store has them.[/QUOTE
Thanks. I didn't understand about the "small copper connector". I did Google DeOxIt & called. They suggested the D5 cleaner & the "Shield". I think that's the way I'll go.
I have wheel bearing grease on mine most of the time.
I have always had a small screw to loosen so I can take out the guts then Twice a year I spray contact cleaner in there and at move it around. Use the contact cleaner to try and actually wash it out. I have had green corrosion in there and used battery post cleaner, then instead of water to wash out, I use the contact cleaner. The last time I did this, I then sprayed it down with silicone and it still looks pretty new in there.
Then on the plug itself, This is what I use, see the link:
Amazon.com: Innovative Products of America 8025 Trailer Plug and Terminal Cleaner Kit: Automotive
Then I spray it down with contact cleaner. It drys quickly, then use just a little dielectric grease on the contact prongs.
I always carry a set of small standard and phillips, which work great for the set screw on the plug. I take the standard, and scrape the heck outta the brass connectors to clean them up. I transport RV's on the side, and half of them have never been touched in years, so they're all jacked up. Works good enough to get it going down the road.
Smokeispower
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
03-14-2014 11:24 AM
Robs06SuperDuty
1999 to 2016 Super Duty
13
07-16-2013 12:33 PM
mcn420
05-26-2006 09:27 PM
