3 speed side shift problem
Old Jan 28, 2022 | 01:36 PM
rbr658's Avatar
rbr658
Got side shift 3 speed installed in 49 F1. Adjusted rods, shifted thru gears pretty good, replaced bushings. Went out yesterday to start truck to move it and gears seem to be stuck. Crawled underneath and unhooked rods from shift levers to see if they moved. One lever would move neutral to 2nd only and other lever moved only between neutral/reverse. Pulled case cover, inspected forks,looked inside then put cover back on, resetting forks. Same deal. Whats ammed up? Ideas?
Old Jan 28, 2022 | 02:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Did you have the side cover off while doing the bushings? Is it possible you installed the 1 - R fork backwards? Should be to the rear as below:
Old Jan 28, 2022 | 02:10 PM
rbr658's Avatar
rbr658
It was all closed up when upper shift arms bushings replaced. Forks are in right location. Smaller 1/rev to back.
Old Jan 30, 2022 | 02:14 PM
Indybeer's Avatar
Indybeer
I had a similar issue with my 3 speed. Check out this link. it might be what is wrong with yours
https://www.ford-trucks.com/forums/1...-3rd-gear.html
Old Jan 30, 2022 | 02:21 PM
f5fordgirl's Avatar
f5fordgirl
Mabey thats the way you took it off, but the front fork isn't in nutural.
Old Jan 30, 2022 | 05:02 PM
rbr658's Avatar
rbr658
Thanks Indibeer. Took cover off again yesterday, put back on. I think i maybe had possibly the R/1 fork tweeked or something. Now I can shift arms into all gears although 1st doesn't seem like going in real solidly. Maybe when I get linkage hooked up and truck under power it well settle.
Old Jan 30, 2022 | 06:04 PM
3twinridges's Avatar
3twinridges
For what it’s worth, both of my trucks when sitting still can be tough to hit all 4 gears. Once you get the gear oil heated up and the engine is running it seems to hit all 4 a little better.
JB
Old Jan 30, 2022 | 08:58 PM
rbr658's Avatar
rbr658
That was my thought, get everything moving. Thanks for the input everyone
bullnose1985
21
Dec 18, 2019 02:20 AM
bill walter
Jan 15, 2018 06:37 AM
E30tdf
Oct 24, 2013 11:23 PM
forguy_50
May 7, 2012 01:48 AM
