Block heater voltage
You have that backwards. Besides amps x volts = watts. If it consumes 900 watts at 120V, its around 450 watts at 220V.
The following users liked this post:
Same as taking a 2000watt 240 volt spa heater and running it at 110 volts.
The one thing that will take them out quickly is what is referred to as dry firing the heater.
On water to cool it down. They tend to go POP very quickly. Last time I was working on
a heater and the flow detection circuit failed, and it went BANG/SIZZLE.
Pulled the control board and shipped it in for repair.
Resistance is the constant in that electrical exercise, not watts. When voltage increases in a constant resistance circuit, then amps increase, then watts really increase (until the smoke is let out).
cowmilker08
21
02-15-2012 10:47 PM
