2" front level feed back.
Old Jan 25, 2022 | 02:38 AM
Bronkxone's Avatar
Bronkxone
I have a 2020 with plow prep and want to lift the front 2" so I thought I would poll the audience. I wanted to do a spring kit with alignment correction and the ones I find are diesel only so I asked Icon and they are 100% against putting a spring kit on a gas truck. Is any one doing a 2" level and if so what did you use and are you happy with it?
Thank you
Old Jan 25, 2022 | 07:56 AM
speakerfritz's Avatar
speakerfritz
there are both under coil spacers or over coil spacers avail to lift the front . a coil replacement will give the best ride. no leads on which coil to use.
Old Jan 25, 2022 | 09:58 AM
kylant's Avatar
kylant
Carli has gas specific coils. They are listed as 3" for the 20+ trucks. My truck got exactly 2.5" from them. I wanted more. I swapped to their diesel coils. 3.5" lift now. ride is slightly firmer, I would say it is still softer than stock
Old Jan 25, 2022 | 05:08 PM
Rwhjr's Avatar
Rwhjr
I used a BDS level kit on my ‘21 (they have it listed for 17-19 trucks but everything worked) with plow prep front springs from the factory
2” lower mount spacer and it came with basic fox shocks
im not running Baja races or trying to set land speed records driving off road in a truck that’s made to tow and haul on asphalt…so keep that in mind
But I’ll say my truck rides noticeably better than it did on the stock shocks and I have no complaints at all
Ron Dog
Mar 30, 2015 10:35 AM
doctor_ratz
Nov 8, 2007 05:42 AM
SooperDudy
Oct 21, 2004 08:52 AM
texaspride250
Mar 3, 2003 12:16 AM
