Front end lift (leveling) kit. Any suggestions?
I was thinking about putting in a leveling lift kit. I don't want to jack the truck up, but I would like to level it out. Can anyone suggest a good kit to do this. I saw a couple of kits in JEGS that use a single spring and a control bar spacer. Is this the best way to level the truck out. Is there any down side to doing this ? I don't want the front end to reach for the stars either, but I would like the truck to sit level.
Thanks
Thanks
There are a few companies that make them for your truck. Superlift, Rancho, Skyjacker. Donahoe racing makes a mini spring pack. There is also a mini spring pack I've seen on ebay. I have an early 1999 model so Superlift was my only option, the springs are sagging so bad I didn't want to go with a mini spring pack.
Thanks
Thanks
I have ridden in trucks that have used both types of kits, the add-a leaf and the hanger. The hanger leveling kit trucks ride a LOT better that the add-a-leaf kit trucks. Our trucks are sprung rather stiff from the factory, when you ADD another spring to the front it makes them even MORE stiff. If I were going to use a leveling kit it would be the hanger type kit from Fabtech, Superlift or Donahoe. All three are good companies that have been around awhile and stand behind their products.
Hope this helps.
Hal
Hope this helps.
Hal
I was just looking around at Wheeler's and saw this deal on the rubicon Express leveling kit. I installed a 6.5 on my friends truck and all brackets looked real strong. http://www.wheelersoffroad.com/fordgaragesale.htm
it was listed in their garage sale section. Kit is regularly $499. Rubicon makes a good strong lift kit. Read the add below:
Sell price was originally 499.00. This leveling system (part # RF52000) uses heavy duty front spring hangers and shackles. It includes a relocation kit for the factory steering stabilizer to increase ground clearance and remove it from it's vulnerable location under the front axle. This system also flips your front u-bolts to improve front end ground clearance. It includes a drop pitman arm and panhard bar drop kit to maintain stock steering geometry. For use with 33"-35" tires. You can use your stock shocks, or some of the shocks listed below
Last edited by horsepuller; 11-01-2007 at 01:04 PM. Reason: [img]http://www.wheelersoffroad.com/ordernow.gif[/img]
I put a ready lift system on my 2005 F350 Diesel 4x4. Then put 35" tires on it. The thing I regret purchasing 35" tires instead of 37" tires that would fit. Purchase the best shocks you can afford. My truck rides and drives much better than stock. This was the best money spent. For a little more money you can put on a lift kit.
Originally Posted by mudmaker
I was looking at leveling kits too, but after considering my pickup has 155k on it I decided to put new springs on first. I upgraded to x code springs and it raised the front a good 2 inches over where it was sitting. The springs where 360.00 delivered from directfordparts.
Originally Posted by Powermoon
Wow, that RE kit looks like a really good deal. Wonder if I can send my tuff country back and purchase that. Just a thought since I haven't installed mine yet.
Moon
Moon
