Reverse lights stopped working
Old Jan 24, 2022 | 09:31 AM
Mjollnir81's Avatar
Mjollnir81
All of a sudden I noticed that both of my reverse lights stopped working. I pulled apart one light, and saw it was pretty caked in what looked like dried grease (tan in color). The bulb element looked good using a meter and I put it back in but no dice. Under the truck I noticed an electrical component/switch mounted to the transmission selector rod assembly. I'm assuming this is the neutral safety switch. Would this also control when the reverse lights come on?
84 F150 base (300 C4/C5?)
Old Jan 24, 2022 | 01:57 PM
FuzzFace2's Avatar
FuzzFace2
Yes
How many wires and colors are they?
Dave ----
Old Jan 24, 2022 | 03:10 PM
Franklin2's Avatar
Franklin2
You did check the fuse? You can also get a testlight and check for voltage at the switch.
Old Jan 24, 2022 | 05:55 PM
BigBlue2's Avatar
BigBlue2
Be sure the bulbs are good and the sockets are clean. Ford did use anti corrosive grease and it's conductive. But if too dirty, dry and caked might need to be cleaned up.
leetudor
Jan 7, 2025 05:37 PM
jfk89150
Oct 23, 2021 02:05 PM
Seanosu
Mar 7, 2016 09:59 PM
bkks744
Jul 7, 2008 06:10 PM
4xfordman
1978 - 1996 Big Bronco
Dec 2, 2001 10:42 PM
