No Reverse Lights
Old Oct 20, 2021 | 06:56 PM
jfk89150's Avatar
jfk89150
No Reverse Lights
I've replaced the bulbs, checked the fuse, and replaced the back up switch. I still don't have reverse lights working yet. I put a paper clip into the female connector that connects to the switch, and got only my left reverse light to come on. If I put in a new switch, why would the one reverse light not come on at least?
Old Oct 20, 2021 | 10:29 PM
marksman76's Avatar
marksman76
try running a separate ground test wire from frame to reverse bulb wiring
Old Oct 22, 2021 | 04:35 PM
jfk89150's Avatar
jfk89150
I took the switch out and plugged the connector back into it, then I pressed onto the ball to activate the switch myself and the one reverse light came on, so why isn't me shifting into reverse engaging the switch? Manual transmission.
Old Oct 23, 2021 | 10:09 AM
Wheeler.M1's Avatar
Wheeler.M1
I had replaced me reverse light switch and was still having problems with them not coming on. I kid you not, I banged on the sideboard under the dash for the hood release, and it came on. Maybe pull the board and check the wiring under it.
Old Oct 23, 2021 | 02:05 PM
marksman76's Avatar
marksman76
different sections of wiring harness, to the switch, then to the rear bulbs.
Check all connections for power with a test light
Superduty.pride
Oct 21, 2011 12:10 PM
atccracing
Jan 12, 2011 09:11 PM
bkks744
Jul 7, 2008 06:10 PM
4xfordman
1978 - 1996 Big Bronco
Dec 2, 2001 10:42 PM
rick
Apr 30, 2000 12:17 PM
