ECT/EOT delta
Old Jan 21, 2022 | 02:21 PM
salimoneus's Avatar
salimoneus
Trailering
ECT/EOT delta
I'm wondering if the numbers I'm seeing FORScan report are considered "healthy" for a completely bone stock cooling system.
This was after driving for about 40 minutes, mostly cruising around 60MPH with a couple short WOT runs from 40-70MPH. Ambient temp was around 30F outside.
After getting home, truck was idling and I took this screenshot showing an ECT of 102F and an EOT of 170F.
That delta of almost 70F seems like a lot, I'd think the coolant should be helping lower the engine temps a bit more, but maybe there's a bottom threshold where the EOT just can't get much lower?
I have driven it in warmer temps (70F but it was before I was using FORScan) and the dash temp gauge always remained very low on the scale, truck is not overheating as far as I know.
Could this be considered normal for the conditions?
Old Jan 21, 2022 | 03:59 PM
fordman67's Avatar
fordman67
The oil coolers on these are not as efficient as one would hope. I would see 210 -220 easily in summer eot.
Old Jan 21, 2022 | 05:53 PM
Dmco's Avatar
Dmco
There is no coolant temp sensor on our OBS trucks, so that PID is a fictitious reading.
Old Jan 21, 2022 | 06:52 PM
salimoneus's Avatar
salimoneus
Trailering
Interesting, I wonder what sensor/input they are looking at for ECT then? Maybe FORScan is estimating based on several data points?
Old Jan 22, 2022 | 08:25 AM
oldbird1965's Avatar
oldbird1965
Its looking at engine oil temp.
Old Jan 22, 2022 | 11:17 AM
salimoneus's Avatar
salimoneus
Trailering
EOT is already up on the FORScan dashboard at 170F, so the ECT seems to be something else. Plus I doubt the oil temp is only 102 after 40 min of driving?
Old Jan 22, 2022 | 11:45 AM
iverger's Avatar
iverger
I thought I read that cold advance (2 degrees) doesn’t even kick off until EOT is 160, 212 is ideal for combustion and 240 is more of an upper limit.
Old Jan 22, 2022 | 02:16 PM
fordman67's Avatar
fordman67
No thanks. my injectors don't like over 210. My goal is under 200.
Old Jan 22, 2022 | 08:09 PM
96 OBS's Avatar
96 OBS
I thought 190-200 is the goal for most diesels. My CR cummins drives highway mid 190s coolant temp. Not sure on oil temp but certainly not far from that. depending on ambient temperature. 7.3 did 198 oil temp almost always
arno
2015 - 2020 F150
27
Jul 7, 2020 02:55 PM
dclack
18
Mar 5, 2014 02:21 AM
BillyBob69
Dec 12, 2013 05:55 AM
cjgray1974
Mar 15, 2013 01:02 PM
grec-o-face
18
Feb 15, 2013 01:46 PM
