Didn't have a chance to check the truck out this weekend. Did plug it in Saturday and she started right up without any smoke and no miss. I get that's warm and a different deal. I do have a couple questions. 1) How hard are cold smoky starts, such as I'm experiencing, on the motor? I don't want to hurt something diagnosing. And am I ok to run it if plugged in to start?
It's only going to wear out the batteries and starter faster doing that. That it starts fine the first time with block heat is an even stronger clue something is still up with the glow plug system. Get one of those power port voltage displays and tell us what the voltage does when you roll the key on before cranking it. Even with it plugged in you can look at this. Sometimes even Walmart or auto parts stores will have them. These are pretty good. Had one for several years and is fine to leave plugged in all the time.
I have an oil change coming up so I'm likely going to go to 5W-40. Good idea on the cigarette lighter port...I've also seen guys have a little red light on the dash.
My e99 7.3 PS had a terrible time starting up in 10 to 20F temperatures (when without power for block heater) and all I did was switch to synthetic 5W-40 motor oil and there's no trouble since!
That was several years ago.
There are at least couple of threads here on this subject.
I realize the fuel injectors are on borrowed time since they have about 220,000 miles of use, but so far so good.
I agree with others this sounds like case of glowplug system playing tricks on you
Here is my 2001 starting about 25* out after sitting overnight. I only let the glow plugs warm for about 5 seconds before I hit starter, just long enough for fuel pressure to build to see how it would do.. You can hear the trombetta relay click in the beginning. 196k mile original injectors and 15-40 oil. https://rumble.com/vtw34y-2001-f250-...-start-25.html
Here is a video of my 2003 a few years ago, about 28 degrees. re-man motorcraft injectors with very little miles, 15-40 oil.
This was before I replaced a sticky glow plug relay. The first attempt was no glow plugs at all, 2nd attempt (you can hear the relay click this time) the glowplugs worked and she fired right off. https://rumble.com/vtw6n6-2003-f250-...-start-28.html
Curious OP, did you have any luck tracking down your issues? Original video that you posted was like sitting in the cab of my 2000 F-350 (320k miles). Similar-ish recently replaced parts. Dying to know if you unwound the mystery
It's a second vehicle since I have a truck provided by work, and I haven't felt like working on it in the cold, so I haven't toyed with it since. The mystery persists, but I'm still dedicated to figuring it out come hell or high water. I'm going to get a couple more tests done this weekend. That will include pulling amps for each glow plug to confirm operation, a fuel pressure test, and use FORscan log to get some more information.
I have been having some issues with this cold weather myself lately while temps are in the 30's-40's. I'm noticing a gurgling sound coming from the fuel pump that is probably air which relates to fuel pressure. I'm thinking the cold weather is shrinking either the rubber hose at the clamp or the o-ring at the tank disconnect as it doesn't make noise when in the upper 40's+. Truck sounds alot like yours trying to start. Next time you fire it up, turn off the radio, open the door, turn the key on, and listen to the pump. At first I thought it might be a bad pump, but it's a Bosch unit that was put on in 2019...boy have they shot up in price...but it sounds right when the temperatures are warmer...
Looking forward to your results, especially with respect to fuel pressure.
In my case, I just inferred the glow plugs were getting power from the ~120 seconds of voltage drop shown by VPWR. Given that my FORscan logs look good and it starts and runs well warm, I'm leaning towards shimming the injectors. Given my mileage, seems like a good thing to check anyway.
