Injector cup life expectancy
Old Jan 21, 2022 | 06:01 PM
ScaldedDog's Avatar
ScaldedDog
Originally Posted by Rot Box 2
Hope I didn’t hijack a thread. Figured since we
were on the topic…
I think your question is right on target, though I don't have an answer. I'd guess heat, but that could be either coolant temp or, I suppose, cylinder temps, but I don't know that either are involved.
Mark
Old Jan 21, 2022 | 06:09 PM
bwguardian's Avatar
bwguardian
I haven't looked at alot of them that have failed, but they look like the ones in this thread...cracked in the bottom half...
brian42's Avatar
brian42
Veteran: Navy
Maybe loose/chattering injectors?
Old Jan 22, 2022 | 07:06 AM
Kwikkordead's Avatar
Kwikkordead
Or air in the fuel, making the equivalent of a "water hammer" effect like when you turn the water off suddenly in an older house?
Old Jan 22, 2022 | 11:16 PM
seijirou's Avatar
seijirou
With the right tools it's not a bad job. Honest the first thing I ever did on a 7.3, mine, was injector cups and with the Riffraff tool it went smoothly. I went for the stainless cups, gave me the warm fuzzy that they won't crack but that's one of those things that's only true until it isn't.
Old Apr 21, 2024 | 05:27 AM
Wildhorse71's Avatar
Wildhorse71
Pull the heads is my recommendation. At 240k your valves are most likely crap anyways. YOU CANNOT go by looks unless you've had it since new. I did mine and the left bank was like new, so I knew it had been off at one time. 3 hr drive each way fro me to find a machine shop that would do the valve job as special tooling is needed.
I would never do another high mileage injector swap again. If I get to 100k on this rebuild, then cups will be done. 250K+..never again
97vanswap
May 18, 2020 09:55 AM
Hawk180
Jul 10, 2012 07:14 AM
sdunn9
Feb 18, 2011 05:17 PM
paintslinga2010
Nov 16, 2008 12:08 PM
blrman1962
May 28, 2007 06:13 AM
