Clunking/jerks while in 4x4
Old Feb 19, 2022 | 03:30 PM
mikren's Avatar
mikren
Been a while but better late then never. the iwe's (actuators)were ****ed. The diaphrams were torn therefore not holding vaccum....obviously. lol
Once I changed those I couldn't get the spindle , actuator and hub gears to "mesh" together....was losing my mind. Turns out the teeth on hub gear worn out just enough to prevent everything from "meshing" together. Installed new hub assemblies and all is well.
tks again to all who helped.
Old Feb 20, 2022 | 09:45 AM
rbentnail's Avatar
rbentnail
I appreciate you coming back, even after all the crap you were given, to tell us the solutions. Thanks!!
Old Mar 27, 2025 | 03:22 PM
SpiritForge7's Avatar
SpiritForge7
2nd Gear
2014 f150 clunk culprit
Originally Posted by mikren
Evening everyone. Been a while. My issue is with my 2013 f150 5.0l 4x4 with 127k
Drove into work yesterday in 4x4 all hwy without issues. When I then slowed down to make a right turn and proceeded on mine road with a slight incline it started to clunk/jerk, ( like pretty hard and loud too)if I let off the gas it stopped and as soon I would hit the gas again it would clunk/jerk again. I switched back to 2x4 and all is good.
My first thought is transfer case? But I dunno. Any help would be greatly appreciated. tks again
Mike
I just got doen replacing the drivers side actuator and while I was working, I noticed a liekly culprit...
While tightening the lug nuts, I spun the wheel some and saw that the cv axle binds a little bit and forces the control arm upwards. The. It releases and the control arm slams back down and impacts the suspension spring.
There is an impact scar from the arm hitting the spring.
Its a brand new Dorman CV axle from O'Reilly.
Brsnd new actuators and cv azkes both sides.
Both wheels function properly in 4wd.. but that cv axle binding under load and thrn releasing the upward pressure on the control arm makes the clunking sound...
I would suggest inspecting your springs and looking for an impact scar newr your control arm....
Not sure how you could remedy this. But, that seems to be the culprit
nmr.inc
2004 - 2008 F150
Sep 11, 2009 12:29 PM
waldreps
May 18, 2009 12:47 AM
Matt99DECH
Feb 8, 2008 12:43 AM
PSDailydriver
Offroad & 4x4
Dec 17, 2003 02:43 PM
kohawk65
Sep 5, 2001 11:56 AM
