4x4 traction stuck
Old Sep 10, 2009 | 10:47 AM
nmr.inc's Avatar
nmr.inc
4x4 traction stuck
Hi everyone. Look I have a little 4x4 transmission problem. When I use it in 4x4 low, and then try to deactivate it doesn't do it at all. Stays with the 4x4 on although the indicator is off. I can only deactivate when I completely stop, active 4x4 again and return to single traction. Does anybody knows why the truck do it?
Greetings.
Pd. my truck it's a F150 Lariat 2004
Old Sep 10, 2009 | 12:30 PM
canstacker's Avatar
canstacker
This is normal, 4low you must stop put in neutral and turn to 4 HI then 2 HI
Old Sep 10, 2009 | 01:48 PM
nmr.inc's Avatar
nmr.inc
hi! thanks for response. Well I do it like you're saying. It's the first time it happens. I am a little worried about it.
Old Sep 10, 2009 | 04:37 PM
Oldguy4's Avatar
Oldguy4
nmr.inc, the next time it happens, try moving the truck in the opposite direction that you have just gone for a couple of feet. It might just be bound up.
Old Sep 10, 2009 | 05:38 PM
Deluxe05's Avatar
Deluxe05
As Oldguy4 said, try backing up in a straight line about 20 feet or so after switching it out of 4 Low. This should relieve any binding that may be keeping gears locked together...which will enable the transfer to actually shift as needed.
Old Sep 10, 2009 | 06:56 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
You have to switch out of 4x4lo in a very specific process. You cannot just go straight from 4x4lo to 4x2 with the switch.
4x4 Lo -> Come to a Stop -> Transmission in Park -> Switch to 4x4 Hi -> Wait for dash to indicate -> Switch to 4x2 -> Wait for Dash to Indicate
and as mentioned, sometimes driveline torque will cause the IWE to get bound up. A simple change of direction (reverse) will do wonders and allow the IWE to release.
Old Sep 10, 2009 | 07:02 PM
cluv15's Avatar
cluv15
I have an 05 xlt screw, and mine won't change unless I'm in nuetral. In park it will not change.
Old Sep 10, 2009 | 08:34 PM
Muddedprairie's Avatar
Muddedprairie
Neutral for me as well. When i shift i go from 4x2 high to 4x4 high then to 4x4 low all in neutral and same going out.
Mark
Old Sep 10, 2009 | 10:23 PM
pb34's Avatar
pb34
Mine changes from 4x2 high to 4x4 high even if I'm in gear but I have to be in neutral to get into 4x4 low
Old Sep 10, 2009 | 11:19 PM
nmr.inc's Avatar
nmr.inc
Thanks you all for response. In fact all your responses was very helpful. I try it this afternoon and work great going backwards a little. Problem solved. But one more question. Is there any way to check if my 4x4 transmission is damaged? just for precaution.
Old Sep 11, 2009 | 11:05 AM
442w30's Avatar
442w30
Driving in 4lo on hard surface is really the only way to hurt the drive train. There is a failsafe of sort to not allow engaging 4lo while moving, imagine dropping into low by accident at 40 or 50 mph...... drive train would be all over the road.
Old Sep 11, 2009 | 12:29 PM
nmr.inc's Avatar
nmr.inc
Yeah! now I know for real. Well I'm new in this 4x4 traction, in fact this truck is my first car jeje. So I really appreciate all your advices and tips. Thank you everyone
GlassLeather&Wood
30
Dec 25, 2020 03:37 PM
wrxin
Nov 4, 2013 03:15 PM
CaptainIPSC
Jun 29, 2012 03:02 PM
VAXB
2009 - 2014 F150
Dec 28, 2010 11:51 AM
