Passenger power window quit working
Old Jan 21, 2022 | 03:32 PM
FordTruckNoob's Avatar
FordTruckNoob
Originally Posted by jstihl
As far as the voltage drop goes, it did it three or four times in a row, I then tried the new switch and it didn't drop, plug the old switch back in and now it's not dropping either so not sure what happened there. I tested for continuity on all of the pins while actuating the switch up and down and I have zero continuity on any of the pins. Also tried this on the new switch . In order for the switch to work I would have to have continuity on something right?
On edit: I tried testing with 2 different dvms, set on ohms , and tried touching the 2 test leads together to see if they showed continuity and they did. Am I doing something wrong here or do I just have 2 bad switches?
It's beginning to sound like you have two bad switches,
Old Jan 21, 2022 | 04:45 PM
jstihl's Avatar
jstihl
Sounds good, I will trade in my switch and report back. Thank you for all the help
Old Jan 2, 2025 | 03:45 PM
rikit's Avatar
rikit
1st Gear
Also, always check the drivers door WINDOW LOCKOUT switch!
'A friend' went down this process of troubleshooting the passenger side switch failure.... ordering a replacement passenger door switch, researching, printing wire diagrams and doing electrical tests on a truck.
Not saying I did any of that, but a good friend of mine did... I bet they feel stupid!!! LOL
Old Jan 3, 2025 | 01:08 AM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Your friend is very much like my friend
Eric White
Jun 27, 2012 12:47 PM
sparks44
Jan 29, 2011 07:37 PM
drew213F250SD
Aug 31, 2010 08:17 PM
truckmonger1
Jun 13, 2010 09:20 PM
Taboo
Jul 24, 2007 12:24 PM
