EGR Value
Old Oct 16, 2000 | 06:02 PM
fordsrus's Avatar
fordsrus
EGR Value
Hi! Have a 1989 F-150 4.9L. Has a miss to it when accelerating. If you unplug the green vacuum hose from the EGR value the miss will go away. And I replaced the EGR value. What could it be?
Old Oct 16, 2000 | 11:11 PM
PAUL_2's Avatar
PAUL_2
EGR Value
The device that controls the egr operation is the Egr Vacuum Regulator . Its mounted left rear on the engine , just below the valve cover . If its malfunctioning it will activate the egr when it shouldnt . Thats one possibility . Check all the vacuum lines to & from the egr also .
Old Oct 17, 2000 | 01:43 PM
fordsrus's Avatar
fordsrus
EGR Value
[font size="1" color="#FF0000"]LAST EDITED ON 17-Oct-00 AT 02:44 PM (EST)[/font][p]I replaced the EVR (Exhaust Vacuum Regulator)today, the regulator that you were talking about. and it still misses. Vacuum lines are O.K. Could it be the TAB/TAD Solenoids next to the EVR?
Old Oct 20, 2000 | 02:36 PM
rlbertrand's Avatar
rlbertrand
EGR Value
Old Oct 20, 2000 | 08:49 PM
warthog299's Avatar
warthog299
EGR Value
I have the same problem with a 1985. I just unplugged the green vacuum line and my truck runs great. Don't worry about the stupid egr valve. Unplug it.
Old Oct 21, 2000 | 11:52 AM
fordmaniac21's Avatar
fordmaniac21
EGR Value
try replacing the MAP sensor. If this is bad it will cause the engine to miss at idle and under acceleration. If you cant fix it try getting a code scanner from the auto parts store th pull the trouble code. You can get one for 25-30 bucks.
Old Oct 30, 2000 | 06:45 PM
fordsrus's Avatar
fordsrus
EGR Value
Replaced MAP sensor toady and still misses. Took it to a scanner today and found no errors or codes. Replaced TAD and TAB. How do you test the fuel regulator, and fuel injectors?
Old Oct 30, 2000 | 07:23 PM
hotrodford_88's Avatar
hotrodford_88
EGR Value
I had the same problem on mine when it had the 6 cylinder in it, and I never found that stupid miss, even after spending $1,000 trying to find it.
I finally took it to a shop, and they cleaned the injectors and that stopped most of it. Then took it to the muffler shop at the advice of the guy at the shop, and found that one of the cats was plugged solid. This is what was causing my miss, of course 6 months after fixing all of that, I got tired of the crappy gas mileage, and performed a heart transplant, and it has run better and gotten better fuel mileage ever since.
Of course, I was only getting 12-13 mpg, out of it constantly, now I get between 14-17 out of depending on where I get my gas.
1988 F-150 Custom to XLT Lariat conversion, 5.0 EFI (formerly 300 I6), 5-speed M5OD, 3.08 rear gears (will be upgraded to 3.55's), Summit headers, Flowmaster muffler W/ dual 3.5" tips 24" long.
Pioneer CD, AC, Tilt, Cruise, Mobile Radio, Lightbar (Force 4 LP6000), Federal Signal PA300 Siren W/100W Siren Speaker. Caution Customizing in progress, Watch for flying tools & Parts!
