Lower Radiator Isolators
Old Jan 18, 2022 | 10:31 AM
shadowplane676's Avatar
shadowplane676
So I have run into a seemingly unobtanium part situation. My 1995 F150 did not have the rubber lower radiator isolators when I pulled out my old plastic-ended radiator. Since I am going with a 3" Aluminum upgraded radiator, I wanted to make sure it wasn't going to break from vibration or wear abnormally from sitting in the steel U ears. The closest thing I have found is on LMC, but they list it for an F250 Diesel. Does anyone know if these are the same for the gas radiators or if there is another source (other than junkyarding and hoping there are some left) for these rubber isolators? Thanks!
its #6 on this diagram at LMC
https://www.lmctruck.com/1980-96-for...and-components
Old Jan 18, 2022 | 12:32 PM
jas88's Avatar
jas88
The part number 43-0929 for "80-84 Gas" would be closer to the right thing IMO.
Old Jan 18, 2022 | 01:10 PM
shadowplane676
Unfortunately, the radiator support I have and the specific radiator appear to not be set up for those isolators. If you look at the radiator linked below, it has two "ears" on the lower mount point that would rest in the shaded J channel in the LMC diagram and have straight metal to metal contact if installed without isolating rubber of some kind.
Exact radiator to be installed: https://www.summitracing.com/parts/s...-150/year/1995
Old Jan 23, 2022 | 08:49 AM
shadowplane676
I was able to find a couple pairs at the junkyard, but the listed ones from LMC (either type) are not correct for your normal F150. I may toy with the idea of making a mould and pouring some polyurethane ones though.
Old Jan 23, 2022 | 10:39 AM
torq'ta 5 8's Avatar
torq'ta 5 8
If any constellation, I just changed mine out and it didnt have the rubber there either?
Old Jan 23, 2022 | 10:43 AM
shadowplane676
I would be surprised if 1 in 3 actually still had them in the truck. With the age of these trucks it makes sense that they were lost over the years.
Old Jan 23, 2022 | 01:58 PM
Scndsin's Avatar
Scndsin
Drop a pic of what you came home with.
Just had mine out & was trying to remember just what they're exactly like, cause I've never seen them spared in the aftermarket.
Old Jan 24, 2022 | 08:30 PM
shadowplane676
Sure, here is what they look like, same on both sides of the radiator. Definitely starting to think of making a mould and casting polyurethane sets as no one I have found has anything like this.
Old Jan 24, 2022 | 08:43 PM
torq'ta 5 8
Wonder how well flex seal liquid, would work
Old Jan 24, 2022 | 09:57 PM
shadowplane676
not sure how flex seal would cure in that thick of an application. I was looking at using energy suspensions purable polyurethane.
https://www.energysuspensionparts.com/diymmi
Old Jan 25, 2022 | 05:23 AM
GNR22's Avatar
GNR22
I looked all over for some of these online a few months ago and came up empty. Also had to resort to pulling them from a junk truck. Seems like an odd thing that would fall into obscurity. Even so though, if all that were available were really overpriced aftermarket poly mounts or whatever, I'd still have opted for the junk yard I guess.
Old Jan 25, 2022 | 12:19 PM
shadowplane676
Out of curiosity, what do you consider too expensive? Most poly bushing pairs/small sets start around $30...
I was already planning on making some bushings for a different car that are not available anywhere else so if I already had the pour-able polyurethane, its not much more to pour a set or two of these...
Old Jan 25, 2022 | 01:13 PM
GNR22's Avatar
GNR22
If they were available for $40 for the pair of bushings, I would have gone that route and ordered new. Any more than that and I'd have gone to the yard and pulled an old rubber set anyway.
Old Jan 25, 2022 | 01:20 PM
Scndsin's Avatar
Scndsin
I've seen some of the guys down in fat fenders & earlier who have poured up bushings with poly for their non-existent suspension parts.
Old Jan 25, 2022 | 01:35 PM
shadowplane676
Its more plausible these days with 3D printing as well. Its what I'm looking at for a few bushings, 3D printed moulds, pourable polyurethane and presto! A part that wasn't available recreated.
