Truck lean to driver side.
Old Jan 18, 2022 | 10:00 AM
theboom's Avatar
theboom
Today I noticed that my truck has a slight lean to the driver side. (7.3, 350 srw) I grabbed a tape and sure enough the driver side is about 1" lower than the passenger. Does ford warranty this or no? If not is there anything I can do about it that won't void the warranty? Could I buy a 1" level kit and only install the driver side or will that cause problems? Thanks for anyone who can help.
Old Jan 18, 2022 | 10:07 AM
David1986's Avatar
David1986
Is your gas tank full of fuel? Could cause it to lean some since it's located on the drivers side. I wouldn't think it would be off an inch though.
Old Jan 18, 2022 | 10:10 AM
morehouse7's Avatar
morehouse7
Google "super duty lean". It's a fairly common thing.
Old Jan 18, 2022 | 10:13 AM
theboom's Avatar
theboom
About half. I afraid to measure it again after I fill up.
Old Jan 18, 2022 | 10:15 AM
theboom's Avatar
theboom
Ya I did that. There was a whole lot of people asking about it with little resolution. Thats why I thought Id try here.
Old Jan 18, 2022 | 10:22 AM
morehouse7's Avatar
morehouse7
Some people have put spacers in, I'm not sure if Ford does a warranty fix. Call your dealership and see what they say about it, they may blow you off so just be aware. I don't blame you, once you know you can't stop seeing it...
Old Jan 18, 2022 | 10:41 AM
Rob89's Avatar
Rob89
It is Super Duty lean.
Old Jan 18, 2022 | 10:55 AM
cpobst's Avatar
cpobst
It's not specific to Super Dutys. If anyone watches TFL Truck when they measure fender well height before and after hooking up a trailer to determine sag I'm sure you've noticed that about every truck they test sits lower on one side.
Old Jan 18, 2022 | 11:14 AM
Sonny Crockett's Avatar
Sonny Crockett
Your box is probably misaligned too but within Ford's margin of error. One rear tire sticks out more than the other. Just enough to notice the difference. They won't fix that either.
Old Jan 18, 2022 | 12:06 PM
KU4OJ's Avatar
KU4OJ
I know a gal who can level that truck right up. Good hearted, sweet and likes to fish.
PM me.
Old Jan 18, 2022 | 12:15 PM
cficare's Avatar
cficare
But they did fix the misalignment between the cab and bed on my 2017. They moved the cab over 3/8" under a 12-month "adjustments" warranty.
cpdorroh
Oct 15, 2018 09:12 AM
Bohemian
Mar 14, 2009 11:48 PM
Still Smoking
2004 - 2008 F150
Jul 3, 2008 06:00 AM
Ultrastealth
2004 - 2008 F150
Feb 22, 2008 04:12 PM
Ford1TonsRock
Dec 4, 2004 02:19 PM
