AGM
Old Jan 17, 2022 | 11:18 AM
petei's Avatar
petei
AGM
Anybody replace the Motorcraft battery with AGM?If yes what brand?
Old Jan 17, 2022 | 02:47 PM
djousma's Avatar
djousma
yep. Autozone duralast platinum. Put in my 2011, and 2016.
Old Jan 18, 2022 | 11:22 AM
Dirthawg2.0's Avatar
Dirthawg2.0
I replaced my leaking factory Motorcraft batteries about one year ago. No issues and no more corrosion on top of the batteries.
Amazon Amazon
Old Jan 18, 2022 | 11:34 AM
HRTKD's Avatar
HRTKD
The corrosion issue is the leading reason why I would switch to an AGM. I'm a bit concerned that the charge produced by the alternator(s) isn't quite what an AGM wants, but it's close.
Old Jan 18, 2022 | 01:42 PM
stryder's Avatar
stryder
Lots of AGM discussions in the 2017+ Super Duty section.
Brands of choice seem to be NorthStar and Odyssey.
Old Jan 18, 2022 | 01:46 PM
Ed in Maine's Avatar
Ed in Maine
Swapped over a few years ago, no regrets. Brand was whatever rockauto had in stock.
Old Jan 18, 2022 | 01:51 PM
HRTKD's Avatar
HRTKD
I think I'm in that discussion already. I've bought four Odyssey batteries. Two for the prior truck and two for my side-by-side. Those are the PC925 model. I had to recondition those batteries because the charge profiles of my solar panel charger and my CTEK charger weren't good enough. Odyssey is an awesome battery if you treat it right. Otherwise, it's just a very good battery.
Old Jan 18, 2022 | 11:06 PM
SARDiverDan's Avatar
SARDiverDan
This is what I use, SLI65AGMDP X2 Power Premium. They have updated the sticker since I purchased mine. I also keep mine on a maintainer as I don't seem to drive the truck much.
Old Jan 19, 2022 | 08:05 PM
23mikey's Avatar
23mikey
x2 Used these in my 2003 Duramax and were still going strong after 8 years when I sold it. Have them in my 2018 F350 and wife's 2012 Expedition. Never any issues, even if left for 2 months like we did with the Expy recently. Would highly recommend this brand, but I think any AGM is a giant leap better than stock Motorcraft.
Old Jan 20, 2022 | 06:57 AM
AmateurWheels's Avatar
AmateurWheels
Sam's Club Duracell AGM. They put them on-sale every spring. Try to get 2 batteries made from the same batch. I've ran Odyssey's and Northstar before. Sams is easy to warranty swap too if needed. Half the price of X2 Power/NS/Odyssey.
Stay away from TSC batteries. Warranty swap is almost non-existent now. You have to call an 800 number, take them to an auto parts store to get tested, and the 800 # is only open M-F 9-5 or something ridiculous like that.
Old Jan 20, 2022 | 07:34 AM
System's Avatar
System
Prolocutor
Odyssey here. No more leakers...
Old Jan 24, 2022 | 01:57 AM
dhag911's Avatar
dhag911
yep worth the money i have those in my 6.0. pickup sitting outside for 2 days highest temp 0 degrees f not plugged in and it cranked as if it was 40 out and started. go online to get a discount got mine through batteries plus
Old Jan 25, 2022 | 09:22 AM
Overkill2's Avatar
Overkill2
My buddy's shop, where I take my truck, stocks Interstate batteries. When it's time, I'll go with Interstate AGMs because I'd rather put the money in his pocket. He takes awesome care of me with also my wife's Escape and my son's Fusion. I have lunch with them often as they are in the city where I work.
Old Jan 25, 2022 | 01:31 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Northstar is no more.
Enersys, the manufacturer behind Odyssey, purchased Northstar, which ironically, was started by the Chief Technology Officer and 3 other executives who quit Enersys to start Northstar, and then later retired and sold Northstar to a European investment company, from whom Enersys acquired Northstar from, thus ending the upstart begun by the defectors.
Soon after acquiring Northstar, Enersys discontinued the brand name (at least, for automotive batteries... not sure about the telco backup battery industry that Northstar also served).
The X2 Power battery is made by Enersys, and but for a lack of tin plating to protect the brass terminal posts and a 20 amp lower CCA rating, is the same thin plate pure lead construction as the Odyssey Extreme.
@HRTKD
Which specific model of CTEK charger wasn't good enough?
Old Jan 25, 2022 | 01:51 PM
HRTKD's Avatar
HRTKD
The third paragraph of this Odyssey document says:
In order to achieve the full design cycle life of ODYSSEY batteries in cyclic applications the charge current must be a minimum of 40% of the battery’s 10-hour rating (column 8 of the chart on page 7). Thus the minimum charge current for a PC925 battery in a cycling application is 10.8 amps (40% of 27Ah).
The CTEK MUS 4.3 charges with a maximum of 4.3 amps. I had been thinking that there was an issue with the charge voltage, but it's the amps as long as I select the right mode on the charger (the third option that is also used for charging a lead acid battery in cold weather) to get 14.7 volts instead of the 14.4 volts used for the regular charge profile.
