Crank no start mystery
Old Jan 14, 2022 | 01:40 PM
Chainfire's Avatar
Chainfire
This is my everyday runner that ran rough on highway then would not restart after pulling over.
2006 f250 studded deleted sctx4. Towed home.
Ficm, crank, cam synch. Icp 1k plus, pulled fuel filter and watched bowl fill. Pulled icp connector. Changed ficm, pcm, main fuse box under dash.
Truck turns over great will not fire even with ether. I also changed pcm relay.
any suggestions?
Old Jan 14, 2022 | 03:26 PM
Hartwig's Avatar
Hartwig
You should not throw parts in.
You should scan the DTCs.
Old Jan 15, 2022 | 07:54 AM
Striderwv's Avatar
Striderwv
Also live PID data. Here's a great thread. Post back DTC's and Live PID data.
Troubleshooting a No-Start condition - Ford Truck Enthusiasts Forums
Old Jan 15, 2022 | 07:59 AM
bismic's Avatar
bismic
AFTER scanning for codes with a quality code reader, then post cranking data:
ICP sensor volts
IPR % duty cycle
rpm
v-reference voltage
injector pulse width command
FICM MPower
FICM LPower
FICM VPower
cames645
2009 - 2014 F150
Oct 23, 2021 08:15 PM
Rusty Axlerod
Apr 18, 2021 10:27 PM
Mark Kovalsky
16
Sep 14, 2017 06:40 AM
06powerstroke06
Aug 13, 2010 09:38 PM
